C4 Door Speaker Install
The problem is I can't get the inner section of the door out (the aluminum inner bracket that holds everything from the door handle hardware to wiring, etc.).
Does anyone out there know of the secret to ge this part out. I've looked in my shop manual and chilton manual and I am not getting what I need. I'm about to unleash the BFH on the project. :banghead:
Thanks for the help.
:seeya
On my 94 it goes like this:
In addition to the several hex-head screws around the edge, there's a phillips screw towards the back. Also remove the lower bolt on the rear window-stop, and it helps to loosen the top bolt on the stop (might want to mark it so you get it back in the same place.)
Now you have to disconnect the two rods inside (door lock and door handle) in several places. Now that everything is loose, move the panel down in the door until you can get the top edge through the opening. Then you have to unplug the wiring from the door lock solenoid.
This is from memory, so I may have forgotten something...
Thanks for the assist!
:seeya
