Sponsored by: Innova
C4 Power Ant
Old Feb 7, 2004 | 12:07 PM
90 Convertible's Avatar
90 Convertible
Default C4 Power Ant
Just replaced the entire stereo in my 90. Antenna worked fine before swap, but now it won't go up. I checked for power at the relay and even put in a new one incase it went bad. Anybody got any suggestions?
Old Feb 7, 2004 | 01:00 PM
DocToss's Avatar
DocToss
Default Re: C4 Power Ant (90 Convertible)
Does the motor make any noise at all? Is there a fuse?
Old Feb 7, 2004 | 01:54 PM
ABNVET.I's Avatar
ABNVET.I
Did you put in a aftermarket stereo? If so did you use a wiring harnes adapter? Because the antenna gets its power from the stereo box under the passngers feet.
Old Feb 7, 2004 | 04:25 PM
90 Convertible
Default Re: C4 Power Ant (1hot90)
I replaced the bose with an Alpine and used a wiring harness adaptor. The head unit is sending power to the relay. It's just hard for me to believe the antenna went bad between radio swaps. I can't find any blown fuses either.
To C4 Power Ant
