Sponsored by: Innova
How do I make it fit?
Old Feb 18, 2004 | 08:44 AM
C5EVIL's Avatar
C5EVIL
Default How do I make it fit?
Hi,
I'm currently installing a regular sized head unit into my C5 - I've done all the wiring and made a good start on the fibre-glassing to finish off the dash.
Then I came to fit the head unit. :(
The gap between the 2 supporting struts that hold the original stereo is much wider than the new standard sized head unit I have.
So my question is simply - what can I use to make the standard sized head unit fit into this hole? Wood? Or does anyone know of an adaptor I can buy or something?
Thanks in advance for any help!
:cheers:
Old Feb 18, 2004 | 10:55 AM
leolufse's Avatar
leolufse
Default Re: How do I make it fit? (C5EVIL)
I'm not sure I understand. You are doing a custom install with fiberglass?
Will a regular HU mounting kit not work?
http://akamaipix.crutchfield.com/pro...0993300-f.jpeg
When I installed my LCD screen and HU, I made a mount out ot 5/8" particle board and covered it with this to give it a "factory plastic look"
http://www.partsexpress.com/pe/showd..._ID=6726&DID=7
Old Feb 18, 2004 | 11:19 AM
C5EVIL's Avatar
C5EVIL
Default Re: How do I make it fit? (leolufse)
Hey Leolufse,
I've taken the panel with the air-con unit and original stereo out of the car while I fit the new units. Behind the factory dash panel, there are two big metal struts which usually house the stereo and air-con unit. These two struts are what I was intending to mount the head units to, but they're simply too wide apart.
Do you know the ones I mean?
:cheers:
Old Feb 18, 2004 | 11:25 AM
bbvett's Avatar
bbvett
You need a dash kit for a DIN radio. A Metra or Schoshe kit. One of the forum members makes a nice one from aluminum. He also makes the plates for the door speakers I think they are nylon on a CNC machine. Maybe someone can chimein with his name.
Old Feb 18, 2004 | 12:28 PM
C5EVIL's Avatar
C5EVIL
Default Re: How do I make it fit? (bbvett)
That's exactly right! If anyone does make them on here, I'm ready to buy asap! I need 2!!
Anyone?
Old Feb 18, 2004 | 06:19 PM
Nelson V.'s Avatar
Nelson V.
The CF member that makes that stuff is vrumvrum.
-Nelson
Old Feb 19, 2004 | 07:56 PM
bart15's Avatar
bart15
Default Re: How do I make it fit? (NelsonV98Vert)
-Nelson
:iagree:
And they can be retro fit to work in C4's too. I missed my fedex delivery of mine from Vrumvrum today.
You can reach Mike Stanzel (aka Vrumvrum) at:
mstanzel@flamingpaperbag.com
Tell him we sent you!
:seeya
Old Feb 19, 2004 | 08:44 PM
knewblewkorvette's Avatar
knewblewkorvette
Default Re: How do I make it fit? (bart15)
:iagree:
and if that doesn't work...do this
:smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :smash: :jester
To How do I make it fit?
