Sponsored by: Innova
who makes a sub box?
Old Feb 18, 2004 | 08:12 PM
firemanrandy's Avatar
firemanrandy
Default who makes a sub box?
I have a JL stealthbox right now with a 10w3v2 in it. I am running a Xtant 301a that keeps blowing the sub. I want a nex box same as the JL except raises up a little to give more sub clearance and volume for a 10w6v2 or a 12w3v2. I want it to be fiberglass if possable. I would assume that would be the best? I am running a Sony head unit with about $800 of Monster Cables, Xtant 301a and 302a amps, Fosgate 1 farad digital top cap, MB Quart seperates front and back, and fatmat throught the entire car. Any ideas guys? Thanks :cheers:
Old Feb 20, 2004 | 09:29 PM
firemanrandy
Default Re: who makes a sub box? (firemanrandy)
ok ANYBODY :confused:
ANY advice :confused:
please :cry
Old Feb 20, 2004 | 09:51 PM
ZF Six's Avatar
ZF Six
Get a custom one made, local audio place, fiberglass would be sweet but get ready to spend some $$$$
Old Feb 20, 2004 | 09:52 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
I have a sub enclosure made by forum member Mike76002.
It is an excellent, quality built box. Try a search and you will find him.
Also here's a link to another place that sells them.
http://subthump.com/
Old Feb 20, 2004 | 11:16 PM
firemanrandy
Default Re: who makes a sub box? (Z06-JIM)
Thanks guy, I think I might just have to go the custom route here then. I know there are cheaper ways, but we aren't talking a pinto here either. I will pay the cash to get it done right.
Old Feb 20, 2004 | 11:55 PM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Cruise-In III Veteran
:iagree: Why are you so intent on getting a JL sub though? There are much better subs out there for that amount of money...Kale is a good member to ask. :cheers:
[Modified by TheWacoKid, 11:56 PM 2/20/2004]
Old Feb 21, 2004 | 01:33 PM
6318's Avatar
6318
do a search for Mike76002
the guys that are using his boxes can't say enough good things about them...I'll be ordering one myself shortly...
Old Feb 22, 2004 | 12:57 AM
vrumvrum's Avatar
vrumvrum
Conquer made an all fiberglass sub box also. Try a search, he did a how to.
Old Feb 22, 2004 | 12:59 PM
firemanrandy
Default Re: who makes a sub box? (vrumvrum)
thanks guys. mike76002 is making them out of wood I believe, is there that much of a difference between wood and fiberglass? I thought that fiberglass was the way to go. Also which sub would you guys recommend then if not a JL?
Old Feb 22, 2004 | 01:14 PM
EatRice's Avatar
EatRice
Randy...you can not go wrong with a JL sub. JL Audio has been a leader in the industry for as long as I can remeber. There are many very good subs out there but it does not change the fact JL is a fantastic sub. Now as far as wood and fiberglass. the major difference for your application is air space. A fiberglass mold can be pulled from your wheel and used for major part of your enclosure. In doing this you maximize available air space. When using wood there is a loss availble air space due to the wood not being able to conform to the all the curves of your well. Also you have to remove the dispacement of the wood itself for the air space in the well. But a fiberglass enclosure usually cost more than a wood enclosure. On average double and often much more. If you can have a wood enclosure enclosure in your well and provide the proper airspace for your sub their is nothing wrong at all using wood. One MAJOR advantage to a custom wood enclosure over a custom fiberglass enclosure is that your car will not smell for a several days of fiberglass. That is a drawback to make a fiberglass enclosure to custom fit.
So really the choice is yours. If you can purchase a wood enclosure that fits the needs of your driver and is less than a custom fiberglass one go for it. The most important thing is that the enclosure is built to the proper specs of the driver. No matter if it is fiberglass or wood....if it is not the right enclosure for the woofer it is not what you want.
Old Feb 22, 2004 | 05:32 PM
MEATHOUSE's Avatar
MEATHOUSE
Default Re: who makes a sub box? (EatRice)
I made mine out of a combination of wood and fiberglass, made the bottom out of wood, and then angled the top so that the sub points more into the car so its not firing at the ground and trunk, PLUS i fit a 12L7 Kicker Solobaric in it which I love and for the price of 180, you can't go wrong.
Quoted cost= 650$
Do-it-yourself cost=65$
Enjoy
Justin :flag
Old Feb 23, 2004 | 02:42 PM
firemanrandy
Default Re: who makes a sub box? (MEATHOUSE)
QUOTE]I made mine out of a combination of wood and fiberglass, made the bottom out of wood, and then angled the top so that the sub points more into the car so its not firing at the ground and trunk, PLUS i fit a 12L7 Kicker Solobaric in it which I love and for the price of 180, you can't go wrong.
Quoted cost= 650$
Enjoy
Justin :flag [/QUOTE]
maybe I will just have to go that route. Any pics?[
To who makes a sub box?
