Sponsored by: Innova
If you pull it, it will come (AC Plug)
Old Mar 2, 2004 | 11:33 AM
leolufse's Avatar
leolufse
Default If you pull it, it will come (AC Plug)
I was pleased to find out that if you take your time, you can route the AC wiring all the way over to the glovebox and not have to extend the wiring.
I'm going to build a mount for it and place it in there. Anybody know how to remove the glovebox?
Old Mar 2, 2004 | 03:18 PM
Nelson V.'s Avatar
Nelson V.
Default Re: If you pull it, it will come (leolufse)
Inside the glove box, toward the back, there are two plastic/rubber pieces that cover access holes. Pry those off to reveal the bolts (10 mm?) that hold the box to the dash support. There are also four or six philips screw above the glove box opening (near the latch assembly striker). I don't remember the sequence to remove, but it probably desn't make a big deal.
[Modified by NelsonV98Vert, 12:19 PM 3/2/2004]
Old Mar 2, 2004 | 03:58 PM
leolufse's Avatar
leolufse
Default Re: If you pull it, it will come (NelsonV98Vert)
:cheers:
Old Mar 2, 2004 | 11:53 PM
Black$heep's Avatar
Black$heep
Nice find. Let know how it goes.
To If you pull it, it will come (AC Plug)
