Early C4 Amp Ground Location
Mar 11, 2004 | 09:40 AM
For those of you using aftermarket power amplifiers: When mounted in the hatch area, where are you grounding your amps in your early C4s?
It is looking like I'll have to drill to get to the antenna ground, I would rather not do that... Is there a better option?
:seeya
Mar 11, 2004 | 01:08 PM
Re: Early C4 Amp Ground Location (bart15)
The carpeted wall behind the passenger seat has a bunch ground off it already. It takes some work to get access to it, but I was already running my signal wires down the middle of the car anyways.
Mar 11, 2004 | 03:44 PM
Another spot I have had luck with is grounding to a Seat track Bolt.
Mar 11, 2004 | 04:23 PM
Re: Early C4 Amp Ground Location (-=Jeff=-)
another vote for the seat bolt!
you can run it under the carpet and it will exit halfway.
That will make sense when you look behind the seat
Mar 11, 2004 | 06:57 PM
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
Re: Early C4 Amp Ground Location (Kale)
Vote # 3 for the seat bolt (were the seat bolts to the floor pan ). It is easy to access and is a solid 12v ground. No need for drilling anything.
Mar 11, 2004 | 07:45 PM
That's where I have mine grounded.
Mar 12, 2004 | 07:08 AM
Re: Early C4 Amp Ground Location (TIMSPEED)
:iagree:
Seat bolt :thumbs:
Mar 12, 2004 | 01:18 PM
Hey, thanks alot guys! I never even thought of the seat bolt(s)!
I love this Website! :cheers:
:seeya
Mar 12, 2004 | 01:49 PM
battery... figured if I had to run one 4 gauge wire, why not run two?
94 ,
amp ,
amplifier ,
amplifiers ,
ampliphiers ,
c4 ,
corvette ,
ground ,
location ,
locations ,
options ,
seat
