New location for C5 tweets
Any additional speakers (regardless of how they are wired) will change the overal impedance. There are two thoughts I had about this.
Since Luv wired the IE tweets with the main tweets, they are receiving the exact same frequency signal as the main tweets. However the lower impedance could have shifted the crossover point sent to the main tweet. So the cutoff relationship between the woofer and tweet(s) has been altered. I doub't this would be detectable however.
The other option would have been to wire the IE tweets from the amp directly, into the IE crossover. This would not modify the main comp. set relationship, but unless the IE crossover points are exactly the same as the main comp set (doubtful), there could be a noticable "bleeding" of frequencies.
I don't know that much about hooking up a system, as this was my first one, but I figured that it's only wires, and if by hooking them up where I did would've screwed something up, it's only more wire to run, and some of my time, but it sounds great to me. You could always buy the CDT Sat 560 cross overs, they have an additional terminal to wire the IEK built right in, but I thought that basically I did the same thing.
http://www.thezeb.com/detail.aspx?ID=1128
They appear to be a high quality unit, but I was too chicken to mix/match the comps and the crossovers. I hope that this helped.
[Modified by LuvmyC5, 10:46 AM 4/30/2004]
Or I could just get these... http://www.woofersetc.com/subcatmfgp...4&1=319&2=1094 I want to get something today. What to do ?????????
As far as the color goes, it doesn't really jump out at you, but you could always mount them in a different spot, either on the pillar, or in the door pulls as some have done. You never know, you might like the silks better anyway.
Good Luck!
I know that they sound really good for the type of music that I listen to though. In my opinion, I think that you made a good choice, and won't be sorry! The Best of Corvette for Corvette Enthusiasts
The way that I mount the Tweets in the "A" Pilar is to peal the stock vinyl back from the bottom of the post, drill my hole that will receive the recessed mounting cup. Skuff the surface with 80 grit sanding disc, using fiberglass reinforced bondo, I create a flat surface at the base of the post arount the speaker hole. After letting it harden, I sand it smooth, spray 3M upholstery adheasive and restreach and staple the original vinyl back over the post. then cut an "X" in vinyl covering the hole and press speaker mounting cup into place. It looks factory and moves the sound stage up giving really good imaging.
I wasn't attacking your system at all. Everyone has different tastes. Thats why we buy Corvettes and others buy Fords
The car is just extremely hard to get quality sound in. The path lengths are next to impossible to get equal (without expensive processors and tuning).
The outside noises are always changing, with other car noises and road speed.
That is why I believe we need to compensate and not have a flat response curve.
