Sponsored by: Innova
help! mayo dented my sub...
Old May 31, 2004 | 03:51 PM
schpodie's Avatar
schpodie
Default help! mayo dented my sub...
I had to grab some groceries...
I had a passenger and couldnt store the goods in passenger seat...
groceries sat in rear area and the heaviest item (big glass jar of mayo) found its way into my sub.
I now have a nice big dent in my DA TDX-12 sub I think the cone might be metal but in any case was wondering what the best way to pull out / pop out the dent might be? Any thoughts welcome. Oh and no more groceries back there...EVER.
thx
--Jesse
Old May 31, 2004 | 09:29 PM
EatRice's Avatar
EatRice
Default Re: help! mayo dented my sub... (schpodie)
Jesse...just so you know there is no damage to the sub with the dent. Only cosmetic. Now there are a few different ways to pull it out. You can use a vaccum to try to get it sucked on and pop it. You can try a very strong duct tape or if it has a vented pole you can use an air nozzle.
Old Jun 1, 2004 | 03:03 PM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Not good, for this very reason I love the old school waffle grill. They are nice and strong although they don't look that cool.
I'd definitly try the above ideas.
Old Jun 1, 2004 | 03:13 PM
Son93SL2's Avatar
Son93SL2
Default Re: help! mayo dented my sub... (89Corvette6spdFX3)
I used a suction cup to undent my older JLw3
Old Jun 2, 2004 | 01:29 AM
schpodie's Avatar
schpodie
Default Re: help! mayo dented my sub... (Son93SL2)
suction cup didnt work, but I will try my heavy duty shop vac and see if that will work. I def need to get a grill...at this point just to cover up the marred surface : (
Thanks for suggestions
Old Jun 2, 2004 | 09:09 PM
Buckeye C5's Avatar
Buckeye C5
Had same thing happen to one of my woofers in home system, a shop vac will fix this very quickly. Hope this helps!
To help! mayo dented my sub...
