Sponsored by: Innova
Rear Speaker Options?
Old Jun 7, 2004 | 09:59 PM
Tide C4's Avatar
Tide C4
7th Gear
Default Rear Speaker Options?
I just had both rear amps repaired by Dr. Dons. In the process I found out one of the speakers is bad. Do I need to replace it with a Bose? Or is there an aftermarket version that will work? If so what are the specs, 6 ohm, 8 ohm, 50 watt, etc.?
It's a '92 coupe, thanks.
Old Jun 7, 2004 | 10:02 PM
KDuniverse's Avatar
KDuniverse
Default Re: Rear Speaker Options? (Tide C4)
if you're not changing all of them, you have to stick with blose
