Sponsored by: Innova
Please help with PIE Cor-Har install
Old Jun 11, 2004 | 07:29 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Default Please help with PIE Cor-Har install
Guys I'm in the middle of trying to put in the CD changer harness and the aux input adapter. I don't seem to have one of the connectors. On the lower right I have the found the 3 pin connector held in place by the white clip as described in this thread. (taking another look it may be the 4 pin...not sure it faces the other way and I haven't tried plugging either into it until I can find the second connector.)
http://forums.corvetteforum.com/zerothread?id=796738
But the only other thing I can find is a connector up the top left with a mating connector but the wires are snipped at about 5 inches and taped over. The wires are Yellow, orange and black. I have searched and searched and cannot find the missing small square 4 pin connector to plug in the harness. It is no where to be found adjacent to the 3 pin. I have uploaded an edited photo to try to illustrate what I am seeing. Not a great shot but maybe it will help. Where else might I find this missing connector. You can view the photo here, if you download it, you can enlarge it and read it better. Sorry for the link but I can't get it up to my photohost right now.
http://f1.pg.photos.yahoo.com/ph/tal...&.dnm=2ca7.jpg
Thanks in advance for your help,
Paul
[Modified by talon90, 7:55 PM 6/11/2004]
[Modified by talon90, 7:59 PM 6/11/2004]
Old Jun 11, 2004 | 08:27 PM
Domin8r's Avatar
Domin8r
Default Re: Please help with PIE Cor-Har install (talon90)
on the bottom right corner where you found the first connector, follow the bundle of wires taped up w/electrical tape under the carpeting. The other connector will be taped w/ masking tape to that bundle about 2-3 inches under the carpet.
I just found this one myself last week and I was going crazy trying to find it too!
Old Jun 12, 2004 | 06:42 AM
talon90's Avatar
talon90
NCM Ambassador
Default Re: Please help with PIE Cor-Har install (Domin8r)
Domin8r, thank you for the reply, Unfotunately it wasn't there either. I pulled the carpet up all the way back to the seat. I also removed the pass side kick panel, and the upper panel that holds the light out and fished around in there. I am beginning to think that upper left bundle with the pigtailed wires connected, is or was it and maybe someone modified it. Do you think the snipped wires stereo related?
[Modified by talon90, 6:43 AM 6/12/2004]
Nevermind, I found a valentine one install tech tip that told me those are the aux power connections.
[Modified by talon90, 9:18 AM 6/12/2004]
Old Jun 17, 2004 | 04:06 PM
UVA Jay's Avatar
UVA Jay
3rd Gear
I had the same trouble on my '02. I found mine under the carpet against the plastic sill ... almost under the sill if I remember right.
And just a little heads up ... I was installing an AUX adapter to my COR-HAR cable and it refused to work until I realized I didn't disconnect the negative battery terminal. I'm assuming you still have to this with a changer, and hopefully your instructions actually mention this.
good luck
To Please help with PIE Cor-Har install
