Sponsored by: Innova
Delphi Roady antenna
Old Jun 15, 2004 | 10:48 PM
SMFCPACFP's Avatar
SMFCPACFP
Cruise-In II Veteran
Default Delphi Roady antenna
Some of you guys said you put the antenna in the waterfall. How does that work?
Old Jun 23, 2004 | 09:44 PM
CCONKLIN1's Avatar
CCONKLIN1
Default Re: Delphi Roady antenna (SMFCPACFP)
i tried it ther and it worked like poopie.
ended up running up the side pillar and mounting on front windshield in the middle.
best,
chris
Old Jun 24, 2004 | 01:58 PM
DocToss's Avatar
DocToss
Mine is in the waterfall and works fine. Easy to run the cable from console to waterfall.
Old Jun 24, 2004 | 03:39 PM
EatRice's Avatar
EatRice
Default Re: Delphi Roady antenna (DocToss)
Mine is installed in the rear bumper. But I just put one in a Z06 under the carpet in the trunk. Works great
Old Jul 11, 2004 | 11:41 PM
ettoredjr's Avatar
ettoredjr
I did not want the XM antenna in the middle of my shale colored dash, so I installed it under the defroster vent and fished the wire down the passenger side of the dash.
To Delphi Roady antenna
