Sponsored by: Innova
dynmatting
Old Aug 10, 2004 | 05:06 PM
Redrum11's Avatar
Redrum11
Default dynmatting
I think im going to put new carpeting in. I plan to replace the whole carpeting throughout the car. Would it be worth it to put Dynamat or some other sound deadening (perhaps more cost effective material) under the carpeting? Any advice would be appreciated. Thanks
Old Aug 10, 2004 | 05:36 PM
Woodstoc's Avatar
Woodstoc
The dynamat is great material, however, very expensive. I just got through with doing the entire rear hatch area with, belive it or not, water heater blanket that I got from Lowes. It has about 3/8" insulation with a foil reflective backing. Did a great job of dropping the level of road noise. Cost: about $40.00 for two rolls which left enought to do behind the seats and then some. Carpet went back in fine. Took about 6 hours from start to finish. Part of the time was spent getting wiring in for a future amp.
Old Aug 10, 2004 | 08:16 PM
muddpile's Avatar
muddpile
I did 3 layers of brown bread (same as dynamat extreme) under my carpet throughout the whole car, plus replaced the factory deadening with the household foam stuff and it made a big difference. I just have to do the doors now as they have started to rattle.
Old Aug 22, 2004 | 02:52 AM
Dalowroller's Avatar
Dalowroller
Woodstoc I've got a ? for yeah when you did yours what did you use to glue it back down? Also on the Sill covers how hard is it to get the carpet off and back onto?
Old Aug 23, 2004 | 12:46 PM
redson's Avatar
redson
Didya use adhesive,or just lay it in and tape the pieces together,before laying the carpet in? I got a roll of the double-sided foil stuff from Lowes yesterday.The stuff I found was 2 sided foil,with about 1/4" insulation in the center.I was, at the very least, going to insulate the trans tunnel.
Old Aug 23, 2004 | 05:16 PM
Woodstoc's Avatar
Woodstoc
Dalowroller,
I didn't glue it in. Didn't want to have to deal with that if the interior ever got wet for some reason. I just cut the stuff to fit, used the silver tape that came with the rolls to seam the pieces together, and it worked like a charm. Put the interior carpet right back over it. You may have to trim the sound deadening a little at some place where the carpet slips under something such as a trim piece.
Old Aug 23, 2004 | 10:02 PM
redson's Avatar
redson
Dalowroller,
Yeah,I got the Reflectix stuff from Lowes.I see now I should have gotten the larger roll though.I'm gonna use it on my Cutlass too.Maybe instead of gluing it all down,maybe double-sided tape in tight areas.I'd like to get it out someday possibly,too.I think for the price,it shouild work just fine,I hope.
Old Aug 24, 2004 | 08:44 AM
Dalowroller
What about the sill covers? I'm redoing them to and I know I'll have to glue it to those
Old Aug 24, 2004 | 09:42 AM
Woodstoc's Avatar
Woodstoc
I stopped before th sill covers. I didn't want to chance screwing up the alignment and causing a leak at the door. Fought those for years with my 82, don't want to do it again.
Old Aug 24, 2004 | 12:20 PM
redson's Avatar
redson
yeah,I'm skipping the sill covers.No heat,or sound coming thru there anyway with the weatherstrip.For now I'm only replacing the front carpet,so I'll insulate the back half later
Old Aug 25, 2004 | 12:26 AM
Dalowroller
Yeah but I'm changing the color so I have to.
To dynmatting
