Sponsored by: Innova
Radio install questions?
Old Oct 2, 2004 | 11:01 AM
da6speed's Avatar
da6speed
Default Radio install questions?
I'm not sure if this needs to be posted here or somewhere else? But anyways, I am going to replace the Bose everything in my car. As far as the head unit I was told I needed to rewire everything, so my question is where do I get a new power source from, and a constat hot? Running the speaker wires is no biggie. I am assuming that all the wires have to be replaced because they are too small unless the Bose system is used. TIA
Old Oct 2, 2004 | 02:40 PM
bogus's Avatar
bogus
I will need to check my helms manual... it is currently in the garage.
There are four wires you will tap into...
1) constant hot
2) switched hot
3) ground
4) power antenna
What year? my manual is for a 92, and it should work with most later C4s, however, if you have an 89, I might have to dig into bastet44s 1987 manual!
Old Oct 3, 2004 | 12:29 AM
LoneStarSoldier's Avatar
LoneStarSoldier
You should be able to find a plug-in harness that will do away with cutting wires at the back of the radio. Use the speaker wires at the speakers and wire around the amps. Unplug the power to the speaker amps.
Old Oct 3, 2004 | 01:06 AM
bogus's Avatar
bogus
Metra does not make one... Scoshe might... I checked their site, and it may not apply to the Bose.
This is for my 92.
Old Oct 3, 2004 | 04:58 PM
EatRice's Avatar
EatRice
A standard GM harness should plug into the Bose harness. You can catch power and ground there. You are better off though to run new speaker wires.
Old Oct 4, 2004 | 12:21 AM
richdwyer's Avatar
richdwyer
My 89 had a bose. Best buy, circuit city or autozone should have the adapter you need so you don't have to cut wiring harness in car. However, you are better off running new speaker wires to the speakers since bose system uses too small of gage on speaker wires and throws amps in to the mess. I used the adapter for the power connections and ran all new wires for the speakers. I also installed speakers in the dash pad instead of in the doors. Sounds much better. Good luck
Old Oct 4, 2004 | 12:38 PM
da6speed's Avatar
da6speed
My car is a 91'. I was told to run ALL new wires because the aftermarket head unit would pull more amperage than the Bose unit. The Bose unit wiring is too small for an aft.mark. unit. I am replacing all the speakers along with the HU.
Old Oct 4, 2004 | 01:36 PM
bogus's Avatar
bogus
huh? I don't buy that arguement... sounds like someone is selling a line of crap, notice the size of the wire coming from the head unit. It ain't that big! The factory power will be more than enough to support an aftermarket head unit.
Old Oct 4, 2004 | 02:46 PM
EatRice's Avatar
EatRice
Bogus is correct. Look at the back of your radio. 18ga power wire...18ga in the car. You are good to go with the factory stuff.
Old Oct 5, 2004 | 10:45 AM
da6speed's Avatar
da6speed
So what your saying is that all I have to replace is the speaker wire? If that's the case this is going to be a breeze. Thanks for all the info.
Old Oct 5, 2004 | 02:16 PM
bogus's Avatar
bogus
That's all you need to do. Have a nice day.
To Radio install questions?
