Sponsored by: Innova
c5 2 or 4 ohm?
Old Nov 17, 2004 | 08:56 PM
D.K.'s Avatar
D.K.
Default c5 2 or 4 ohm?
I'm getting ready to buy an Image Dynamics Sub and a MRD-M301 Power Amp for starters in my audio upgrade. I notice it comes in either 2 or 4 Ohm. Which should I get for my C5?
Also, do I need to buy this factory interface kit my audio installer says?
TIA, DK
Old Nov 17, 2004 | 09:30 PM
EatRice's Avatar
EatRice
You need to match the sub to the amp. What amp are you using and what impedance will it safely run at? Personally I like to use a 4ohm load with a large amp vs a low impedance load on a smaller amp. But there are other factors to consider. Anyways...what amp are you using?
What interface kit are you referring to?
Old Nov 17, 2004 | 10:13 PM
D.K.'s Avatar
D.K.
My installer wrote this on the estimate: 1 AMP MRD-M301.
He also recomended the Image Dynamics IDQ10 for the sub. Does this sound good?
The kit? The estimate reads: Factory Radio Interface.
Thx, DK
Old Nov 17, 2004 | 10:51 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
you either want a 2 ohm sub or a dualvoice coil 4 ohm sub, they both equal 2 ohms which is where ur amp makes its 350watts rms
Old Nov 18, 2004 | 01:38 PM
leolufse's Avatar
leolufse
this is the set up that alpine intended.
To c5 2 or 4 ohm?
