Sponsored by: Innova
Help- C5 remote wire
Old Nov 24, 2004 | 12:12 AM
InSaNeKaMeL's Avatar
InSaNeKaMeL
Default Help- C5 remote wire
hi, i got my sub and amp working. I didnt feel like taking the radio out so i hooked up the remote wire to a fuse in the fuse box. the fuse that its is on now only gets power when the car is on, or key click into on position. I was going to hook it to the bose fuse but it always has power. how should I hook the remote wire up? it works for now but need to change it. thanks
Steve
Old Nov 24, 2004 | 11:08 AM
leolufse's Avatar
leolufse
Steve
Assuming you don't have a 2004, there is an accessory wire harness in the passenger fuse compartment that will do just what you want. Its on the upper left hand side and has 3 wires. Orange is constant power, Yellow is switched power, and Black is ground.
Old Nov 24, 2004 | 12:16 PM
InSaNeKaMeL
Yea It's a 2000. So i should hook up the remote wire to the yellow wire? thanks for your help.
Steve
Old Nov 24, 2004 | 12:33 PM
leolufse's Avatar
leolufse
Steve
Yup. This switched power wire works in both the ACC and ON positions of the ignition switch.
Old Nov 24, 2004 | 02:16 PM
Nelson V.'s Avatar
Nelson V.
Does the switched wire retain power until the key is removed (up to 15 minutes I think?) or does it power down immediately after turning the ignition off?
To Help- C5 remote wire
