Sponsored by: Innova
Help with Alpine Install
Old Dec 31, 2004 | 07:49 PM
TheHammer's Avatar
TheHammer
Default Help with Alpine Install
I own a 97 coupe, and have an Alpine model CDA-9827. It has a wire, orange I believe, that should connect to an illumination lead so that the face of the unit will dim when the lights are turned on. There is no wire that connects to the orange wire out of the factory connected harness. Does anyone have a suggestion of how to get this function to work and what wire I need to splice into? Is there an illumination lead close by
i can use?
Old Dec 31, 2004 | 08:50 PM
bogus's Avatar
bogus
Don't fuss with it.
I have never attached a dimmer wire in my life! Then again, not many actually have one!
I suspect to do so, you will need a harness breakdown. I am sure there is one on the radio harness, but the adaptor more than likely does not include it.
Old Dec 31, 2004 | 09:33 PM
snoopdan's Avatar
snoopdan
Not worth the effort.
Probaby an orange/white wire on the harness, if its even there. otherwise I x2 what bogus said.
snoopdan
Old Jan 1, 2005 | 12:48 PM
TheHammer's Avatar
TheHammer
Does anyone know where to get a harness breakdown?
Old Jan 1, 2005 | 06:16 PM
bogus's Avatar
bogus
It's called the Helms Manual.... www.helminc.com
Or, http://www.corvetteradios.com./Page.html
might help some...
Old Jan 1, 2005 | 06:31 PM
EatRice's Avatar
EatRice
I believe the illumination is controlled through the BCM like the ignition wire. I have tagged the illumination wire on the the fog light switch.
Old Jan 1, 2005 | 07:05 PM
gmosley's Avatar
gmosley
Default illumination
from what ive read you can tap illumination from the hvac controls harness
Old Jan 1, 2005 | 11:02 PM
TheHammer's Avatar
TheHammer
Does anyone know which wire that is in the hvac unit is the illumination lead? If not, I will be trying the helms.
Old Jan 1, 2005 | 11:34 PM
bogus's Avatar
bogus
did you try the link I posted above?
Old Jan 2, 2005 | 02:13 AM
gmosley's Avatar
gmosley
Default test
just a quick question related to the dimmer-illumination wire would the voltage sent to the wire vary with brightness or if not voltage what would vary up or down depending on the switch position
Old Jan 2, 2005 | 10:23 AM
TheHammer's Avatar
TheHammer
I tried the link to corvette wires, and the gray wire may be the one. Otherwise, there is no dimmer wire apparently.
To Help with Alpine Install
