Sponsored by: Innova
trunk mounted nav controller locations??
Old Jan 11, 2005 | 02:26 PM
leolufse's Avatar
leolufse
Yup, velco sounds ghetto, but it works great for many applications. Make sure you get the industrial strength stuff thought. Also instead of using MDF with Liquid Nails, you can use MDF with silicone caulk. It will hold just as well, but unlike Liquid Nails, you will be able to gently pry off the MDF strips from the car if you decide remove the mount later on.
