Sponsored by: Innova
C5 CD Changer Harness Location
Old Jan 10, 2005 | 05:01 AM
marksr's Avatar
marksr
Default C5 CD Changer Harness Location
I have a 2004 Coupe and am looking for the CD Changer wiring harness in the trunk. Before I rip up all the carpeting, can anyone give me a hint or picture of where to look? I want to attach an IPOD interface. I took a quick look and feel in the 3 hatched compartments but did not find it. Should I look on Driver side, Passenger Side, Center, etc?
Thanks for your help.
Old Jan 10, 2005 | 08:46 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
If you don't have the 12 disk changer in the trunk then I think what you're looking for is in the passenger footwell under the removable carpet, next to the fuse panel. It should be a 4 connector plug with black, green/wht stp. tan/wht strp, and bare busswire.
Old Jan 10, 2005 | 10:56 AM
Vate's Avatar
Vate
Marksr,
To add onto that...
To connect your iPod directly, you'll need both the cable that would have run to the back hatch area if you had a factory CD player, and an adaptor that "fakes out" your HU to believe a CD player is attached.
Here is the cable you'll need:
http://www.logjamelectronics.com/piecorhar.html
And here is the adaptor:
http://store.yahoo.com/logjam/piegm10aux.html
Together, that's about $150. You'll also need an iPod interface that will give you RCA outputs for your iPod. I recommend this one, which also charges your iPod:
http://catalog.belkin.com/IWCatProdu...duct_Id=149006
You'll also need a y-cable that converts a 3.5mm jack to two RCA connectors, such as this:
http://catalog.belkin.com/IWCatProdu...duct_Id=172348
I buried both of these in my dash, and have just the iPod interface cable visible.
When I looked at the cost of this, combined with my dissatisfaction with the factory stereo, I decided to replace the entire system. I direct connected my iPod to my Sony HU using the Belkin connector and it sounds/works great.
Old Jan 10, 2005 | 10:57 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
the car is not pre wired with the changer harness in the trunk, the connectors for the changer harness are in the passenger side footwell.
Old Jan 10, 2005 | 09:07 PM
hansenisu's Avatar
hansenisu
St. Jude Donor '10
I just hooked my Rio Karma up to the factory HU using the AUX-10 (I had the factory CD changer in the back well). It was easy and it sounds AWESOME. The RIO has a couple of 5 band equalizers (regular and parametric) and I can get a ton of bass from the stock unit.
Old Feb 6, 2005 | 06:57 AM
marksr's Avatar
marksr
Do you know the purpose of each of these wires? i.e. power, left/right audio, ground
To C5 CD Changer Harness Location
