Sponsored by: Innova
Powered Subwoofer?
Old Jan 15, 2005 | 04:51 PM
Fastgenious's Avatar
Fastgenious
Default Powered Subwoofer in a Z06?
Has anyone installed a powered subwoofer in a 04 Z06? I would like to stay with my stock system and add some bass and thought this might be an easy and efficient way to do it. What powered sub would you recommend? Thanks
Old Jan 15, 2005 | 11:08 PM
AEmedic's Avatar
AEmedic
I was thinking the same thing. I have an 8" bazooka tube and I was thinking about how I would install it...
Old Jan 16, 2005 | 12:13 PM
Fastgenious
I am thinking about a Kenwood Woox-very small sub. The interior of the Z06 is small so I am thinking that this powered sub would add plenty of bass for my tastes.
Old Jan 16, 2005 | 02:32 PM
snoopdan's Avatar
snoopdan
Bazooka 10" or 8" amplified sub. Price new from $100 to $250. Used prices vary from $25 to $75. If you dont like the way it sounds, mount it in your moms car But they sound great for what they are, and easy to add, all models come with line level inputs, that you can just wire into your stock speakers for an audio signal. I suggest the 8" 200 watt model. It comes with a 2x50 watt amp also in addition to the 100 watt amp for the sub. That way, you can easily upgrade to some bose replacements if you want to at some time, and you'll already have some extra horsepower.
Infinity Basslink
Clear Version
Black Version
This has a 10" driver and a Class D amplifier built right it, with 200 watts. Lots of people like these guys. Price : Used around $120 new $200-300. Has line level inputs as well, can just hook up directly to your existing Bose crap for an audio signal. Infinity makes an even larger version, with 2 passive radiators, but will not fit in the trunk of a vette, as it measures out to be 42" wide. Just a bit too big.
Welp, thats my suggestions, if you just want to buy a box/amp combo.
snoopdan
Old May 3, 2005 | 12:48 PM
OdinsRage's Avatar
OdinsRage
lol no... I remember listening to one in a porsche 911 coupe, in a VERY expensive setup... the head unit was mcintosh
Anyways, sounded terrible, barely any bass output, a stock C4 bose system would out-do it
The infinity basslink or bazooka system works well... but... the best sub for a C4 ever is a polk mobile monitor C4 sub box... Will post pics soon
Old May 3, 2005 | 11:51 PM
markcz's Avatar
markcz
snoopdan
NO, NO, NO!!!!! The Bass signal is NOT present at the twiddlers in a C5
I have a 6" BTA6100 100W Bazooka in my '01 coupe that I tried to wire up like that, but it won't work. You must either run wires from the stock bass speakers in the doors or get an adapter to put behind the head unit that separates the full signal before the Bose amps get ahold of it.
Check out this post of mine from a few months ago for some more info.
Old May 3, 2005 | 11:58 PM
OrthoAggie's Avatar
OrthoAggie
[no]
To Powered Subwoofer?
