Autocrossing & Roadracing Classifieds Post your For Sale or Wanted Autocrossing & Roadracing parts here.
FS: 2001 C5 Z06 Race Car (Clean KY Title)
Old Nov 28, 2025 | 10:04 PM
Ekroeger2006's Avatar
Ekroeger2006
Default 2001 C5 Z06 Race Car (Clean KY Title)
BODY/ WHEELS/ SUSPENSION
- 2001 Z06
- Faircloth Widebody Quarter Panels & Front Fenders
- ACP 2 piece Front Bumper w/ 4" Splitter (not installed)
-ACP Carbon Fiber Undertray for matching bumper listed above (not installed)
- Zebulon 72" Carbon Fiber ZWG-260 Wing w/ Upgraded 2D CFD Carbon End Plates
- Zebulon Wing Mounts & Uprights. Wing is Swan Mounted
- Trackspec Hood Louvers installed ( I have oversized Race Louvers to replace the Trackspec ones. Much more cooling efficiency)
- APEX Forged VS5RS 18x11 +54 offset squared in Brushed Clear. (These were for a narrow body C5. Would need widebody C6 fitment or spacers to compliment Faircloth panels).
- SKF Race Hubs on all 4 corners w/ 3.25" ARP studs
- AMT Spherical Bearings in all control arms and rear lower shock mounts.
- Strano 2 way adjustable front sway bar w/ adjustable end links
- Ridetech rear adjustable sway bar w/ adjustable end links
- AMT Engine Mounts
- AMT Double Barrel Trans/Diff Mount
- AMT Camber Kit
- FDF Factory Style rear inner Toe Links
- All new GM ball joints, MOOG inner and outer tie rods all replaced in last 2 years
- Rebuilt Power Steering Rack from Turn1
- Strano Custom Valved Penske DA 8300 Coil Overs. Upgraded Banjo fittings & built with progressive bump rubbers to keep shock from ever bottoming out. 600lb Front springs, 700lb Rear springs (0 miles)
- Canisters on Rear shocks mounted on down tube of cage & accessible at trunk.
- Canisters on Front shocks mounted on front frame rail near bumper
- MYLAPS lifetime, non subscription, hard wired transponder installed
- Brand New Vette Lights LED Halo Tail lights
- HID headlights (all still functional)
- After Dark Speed Front & Rear Toe Hooks
- Battery Relocated in rear cubby, using OEM C6 battery harness, brand new GM battery.
- TAC Module & PCM relocated behind dash inside car (to make room for future dry sump tank)
INTERIOR
- Phoenix Performance Roll Cage
- Nascar bars on both sides
- Door Bars have 2 frame contact points per side
- Finished in Cyber Gray Metallic w/ multiple coats of clear
- Lifeline AFFF Electronic Fire Suppression System (1 button console, 2 button on exterior pillar by mirrors)
- Fire Suppression Controller mounted in Center Console
- Sparco Pro 2000 Seat
- Phoenix Performance Seat Rail & mount (similar to AMT)
- GForce Side net w/ GM buckle securement
- Safecraft Center Net w/ quick disconnect ratchet latch tensioner
- Master Cutoff & Killswitch installed
- Sabelt 6 pt Harness
- Parking Brake removed, plate installed to cover in cockpit
- 4 accessory switches installed, relays mounted on passenger side under dash
- Coolshirt System installed in pass floor w/ variable controller mounted in center console.
- TMOD Shifter
- Shortened Rear Floor w/ custom tray. (This allows rear diff/trans removal without completely dropping subframe. Also makes room for Diff/Trans coolers to be mounted on the bottom if you choose to do so in that location)
- AMT Pedal Extender
- NRG quick disconnect adapter & steering wheel
- Car retains factory dash, gauges and center console. No warning lights on dash
- Brand New Steering wheel position sensor
- Passenger seat studs were kept if you wanted to add a passenger seat back at some point
- Airbags removed
- All A/C components removed behind dash & Firewall Plate installed
- SFI roll bar padding
DRIVELINE/ MISC
-OEM LS6 engine w/ 55k miles
- CHE Trunions
- New LS7 lifters in 2023
- All Gaskets Replaced in last 2 years (Front seal, Rear Main, Head Gaskets, Valve Cover Gaskets etc)
- OEM Exhaust manifolds w/ Factory mid pipe (cat delete) & Borla X pipe on back half.
- Billy Boat Exhaust (B&B) Route 66 Axle Back
- ATI Balancer
- New LS7/LS2 Water Pump
- Turn1 HP2 Track Power Steering pump
- Derale Upgraded Power Steering Cooler (mounted in factory location)
- DeWitts Oversized Radiator
- Upgraded SPAL dual engine fans
- Mighty Mouse Catch Can
- Improve Racing Oil Pan Baffles installed
- Brand New OEM clutch Master
- Brand New Raybestos Brake Master Cylinder
- Motul 660 Brake Fluid (Brake system & clutch)
- AP Racing Radi-Cal 9660 Front Brakes w/ 372mm Rotors. ENP Calipers. FERODO DS1.11 pads
- OEM Rear Brakes w/ KNS Rotors. Carbotech XP10 pads
- Stainless Steel Brake hoses on all 4 corners
- Fully Rebuilt & Upgraded T56 Base Model Transmission (Taller 3rd gear, 0 miles)
- Carbon Blocker Rings
- Billet Keys 1-6 Gear
- Bronze Pads 1-6 Gear
- Steel 3/4 Fork
- Sliders 1-6 Gear
- New Bearings
- New Seals and Gaskets
- Media Blasted and Painted Case
- Fully Rebuilt C5Z Differential (stock rebuild, 0 miles)
- New Axle Seals & Case Gaskets
- Fully Rebuilt Torque Tube (0 miles)
- New 12mm Couplers 1 solid, 1 rubber
- New Bearings
- Brand New LS7 clutch w/ RAM lightweight Flywheel (0 miles)
- New GM Slave
- Tick Speed Bleeder Installed
- SCCA Log Book
- Fluids in engine (Redline 10w-40), fluid in transmission (Redline D4), Fluid in Diff (Redline 75w-90)
- Car made 370.86 RWHP & 372.25 RWTQ on dyno as it sits. That's OEM C5Z w/ cat delete and tuned.
Car was tuned by James Short @ Shortuning
I may be forgetting a few things. If you have any questions, feel free to ask. No corners were cut on anything. It's just been sitting since I got it back from Phoenix. Significant loss of income is the only reason for selling. I'm asking $58,000 for everything. Over $90k into this car as it sits. If somebody is serious, we can always talk. This car is literally an LS3 swap away from being a super competitive NASA ST1/2/3 car. Car is located in Louisville, Kentucky. May possibly trade for a street car, older muscle car, etc.
Old Dec 22, 2025 | 08:41 AM
blckss's Avatar
blckss
Wow - gorgeous, job well done! Awesome parts and combinations. GLWS.
Old Dec 22, 2025 | 01:20 PM
Ekroeger2006
Thank you, appreciate that
Old Dec 30, 2025 | 10:34 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Bump for an impressive build! Is there a replacement lined up already?
Old Dec 30, 2025 | 02:17 PM
Ekroeger2006
Unfortunately no replacement lined up. Loss of income and job change is forcing the sale.
Old Dec 30, 2025 | 02:20 PM
arthursc2's Avatar
arthursc2
I can't see your text on mobile, so the answer to this may be in there...
would you consider selling the Electron Sport front fascia separately?
Old Dec 30, 2025 | 02:24 PM
Ekroeger2006
I would prefer to sell it with the car. If the car sells or buyer negotiates price without it, I will sell seperate. Just not at this time
Old Jan 5, 2026 | 03:30 PM
Ekroeger2006
Price drop to $54,000
Old Jan 5, 2026 | 11:31 PM
olblue75's Avatar
olblue75
What is the blue tank in the back? Accusump an this is was a killer build.
Old Jan 6, 2026 | 07:26 AM
Ekroeger2006
The blue tank is the bottle for the Lifeline fire suppression system
Old Jan 15, 2026 | 06:14 AM
Ekroeger2006
Bump
Old Feb 22, 2026 | 09:41 AM
Ekroeger2006
Price drop to $50k
To 2001 C5 Z06 Race Car (Clean KY Title)
