FS: Intercomp SW500 E-Z Weigh Cabled Scale System
Large, easy-to-read backlit display
Displays in pounds or kilograms
Displays all four corner weights and percentages of weight
Displays any combination of corner weights and percentages
Stores 100 chassis setups with baseline setup recall
Calculates center of gravity
Operates on a standard 9V battery (included)
Certified to 0.1% accuracy
Low-profile 15 x 15 x 2.5 inch billet aluminum scale pads
System capacity 6000lb/2800kg (1500lb per pad)
Heavy-duty, replaceable color-coded cables
Includes control box case
You can buy cheaper scales with inferior parts that might not last very long, There is a reason why they are cheaper.
Paid over 1800 2 years ago. Only used it a handful of times on my Corvette. Just don't need it anymore. SALE TERMS: This part is used and it will have signs of wear and minor scuffs and scratches. The plastic protective film is scrathed and not removed off of the scales. One of the plastic clips broke on the plastic case.
WILL ship through FEDEX usually the next day after payment is received. All items are shipped with tracking, signature required insurance.
Asking 1200.00 firm
You realize your pictures are 1/4 the size of the tiny avatar pictures? Actually a lot smaller than that even?
