Spring rates..
Old Feb 4, 2005 | 11:40 PM
RogueVette's Avatar
RogueVette
Cruise-In III Veteran
Default Spring rates..
Does anyone know the spring rate of the T1 Front spring.
I am looking at a few different VBP springs and was wondering for comparisons sake. Been told to run a 1000# front spring by a pretty knowledgeable Racer/Tuner.
Also if anyone knows the rate for the Z06 Spring that would help as well again, just for a bench mark.
Old Feb 5, 2005 | 03:22 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
my VBP springs are 1000 frt and 796 rear with revalved Bilstein Sports
Old Feb 5, 2005 | 07:22 AM
AU N EGL's Avatar
AU N EGL
C5 spring rates
Spring Rates, Front/Rear, *lb/in: (Base)440/577 (MSRC)457/577 (Z51)525/634 (ZO6)525/714
I also would like to know the T1 spring rates.
Old Feb 5, 2005 | 04:38 PM
RyanZ06's Avatar
RyanZ06
Why the change the front/back spring bias when going with T1? I see the rear spring is considerably stiffer on all the models, but people install a 1000lb front and a 700-800lb rear spring? Is there logic behind this? Curious...
Old Feb 5, 2005 | 07:50 PM
leaftye's Avatar
leaftye
Check out the C5 General Sticky.
Old Feb 8, 2005 | 03:52 PM
Paras's Avatar
Paras
Any idea how this compares to coil spring rates? Seems awful stiff if that's a direct correlation...
And can I ask what was done when your Bilsteins were revalved (were compression and rebound increased or decreased)?
Old Feb 8, 2005 | 04:08 PM
95jersey's Avatar
95jersey
John,
What did you have before your aero kit?
Old Feb 8, 2005 | 06:06 PM
John Shiels
Matt I had Z-51 but I did have them before the body. It was preperation for the body kit and downforce.
Paras they are not a direct comparison between leaf and coil.
Old Feb 9, 2005 | 01:05 AM
Paras's Avatar
Paras
Darn... ok... thanks... I'm really curious as to what my coilover spring rates compare to...
To Spring rates..
