Spring rate conversion formula?
Sep 10, 2005 | 08:51 PM
I've been trying to come up with a formula to convert srping rates from Newtons per mm to Pounds per inch. I've been trying N/.2248089=lbs. The .2248089 being the newton to pound conversion. Any racers who work with both? any help greatly appreciated.
Sep 11, 2005 | 01:35 AM
don't you have two conversions to make N to Lbs and mm to Inch?
25.4mm=1"
.2248089= 1N
1 newton/square millimeter = 145.037738 pound/square inch [absolute]
conversion site
Sep 11, 2005 | 07:53 AM
From: Buy USA products! Check the label! Employ Americans
cool site
Sep 11, 2005 | 08:11 AM
Cruise-In II Veteran
Really good site, thanks!
Sep 11, 2005 | 10:49 PM
Quote:
25.4mm=1"
.2248089= 1N
conversion site
You gave the conversion for pressure, the correct one for spring rates is 1 N/mm=5.7101 LB(force)/in.
Sep 12, 2005 | 04:07 PM
It all works though
I've been trying a formula that i came up with and all other formulas listed here and i keep coming up with the same spring rate so hey long as it works right? big thanks to all involved in helping to get this one answered.
Dec 28, 2018 | 06:38 AM
1st Gear
I Suggest to use this unit converter to get quick and accurate measurement conversion.
Jan 6, 2019 | 08:39 PM
I have used: ( N/mm / 0.175 = lb/inch ) to convert spring rates, got that from another forum member awhile back.
