Who is using these swaybars
Old 05-22-2006, 11:28 PM
HeyFred
HeyFred's Avatar
Default Who is using these swaybars
http://www.pfadtracing.com/products/...&search=&page=
Keith
Old 05-22-2006, 11:37 PM
emf
emf's Avatar
I haven't run them, but I'm about 99% sure I saw these bars under development a little while ago. As I recall, they weren't at T1 stiffness, but closer to the Hotchkis bars. At the point however, they were generically working fairly well and trying to ratchet down final stiffness . . . . so they may have gone stiffer or softer than when I saw them. Guys doing the development were pretty detailed in their work, and were fairly knowledgable.
. . . depending on what you're looking for it may meet your need, but at a minimum they should be sharp enough to directly answer q's. Track they were testing at was fairly technical, so the bottom-line research should be fairly comprehensive.
(sorry . . . not the answer you were probably looking for)
Old 05-22-2006, 11:42 PM
HeyFred
HeyFred's Avatar
I called them today and asked tech service.
Nobody picked up so I left a message.
Hopefully, they will call back.
Keith
Old 05-22-2006, 11:44 PM
emf
emf's Avatar
. . . . . it was a small operation . . . . . they'll probably call back in a day.
Old 05-23-2006, 06:36 AM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
Old 05-23-2006, 10:27 AM
vetteztr
Navigator
vetteztr's Avatar
I have been running the Pfadt Racing sway bars, along with a roll bar all year. So far I have run at Spring mountain in Nevada and Miller Motorsports here in Salt Lake city.
They are a very well engineered piece, and the adjustability is nice. Fit is great, and they look incredible.
In the past I have run z51, Hotchkis and T1 bars. The Pfadt bars are great.
Old 05-23-2006, 11:41 AM
95jersey
95jersey's Avatar
$700+ ...no way...don't care if they turn you into the space shuttle.
Old 05-23-2006, 12:17 PM
Wicked Weasel
Wicked Weasel's Avatar
St. Jude Donor '05-'08
always the man of reason -
should we buy $300 rotors - No Way
should we buy custom numbers - No Way
BTW - you have saved me tons
Old 05-24-2006, 01:51 AM
dagon138
dagon138's Avatar
Does anyone know anymore details about their coilover kit?
To Who is using these swaybars
Quick Reply: Who is using these swaybars
