335/30/18 rears on CCW's..what do I need to do to fit??
Old 06-27-2006, 11:01 PM
Z06 Silver Bullet
Z06 Silver Bullet's Avatar
Default 335/30/18 rears on CCW's..what do I need to do to fit??
Car is lowered but not to max.
CCW's (don't know offset,etc..) that are 18x12.
I would love to run these in rear and 315/30/18 in front on my 18x11's. Should be much better than 295/30/18 front and 315/30/18 rear??
Old 06-27-2006, 11:21 PM
GTB/ZR-1
GTB/ZR-1's Avatar
Remove brake cooling duct, and you may need to run a small spacer (I run .11") on mine w/ 335/17-12" setup and don't have any issue w/ any inner fender rub.
Old 06-27-2006, 11:57 PM
emf
emf's Avatar
Need the offset to be able to tell for sure. Mine, I run a .850 spacer on an 18x12. Since they're typically built to order . . . . .the devil's in the details.
Old 06-28-2006, 08:43 AM
AU N EGL
AU N EGL's Avatar
I run a 3/8" spacer on mine
and 3/4" fender flairs
To 335/30/18 rears on CCW's..what do I need to do to fit??
Quick Reply: 335/30/18 rears on CCW's..what do I need to do to fit??
