RA-1s on front and CORSA System on back?
Old 06-28-2006, 10:40 PM
C5nNC
C5nNC's Avatar
Default RA-1s on front and CORSA System on back?
C6 R compound tire question
OPTION 1 - Run stock rims with Toyo RA-1s on front and new Pirelli Corsa System tires on rear
OPTION 2 - Run stock rims on front and aftermarket 18 X 10.5s on rear with RA-1s all the way around (figure in cost of buying rims)
What do you think?
Old 06-28-2006, 11:33 PM
BQuicksilver
BQuicksilver's Avatar
Cruise-In III Veteran
Cruise-In IV Veteran
I'd go option #2. IMHO 2 different compounds will just cause the handling to vary more as one compound gets sticky/slick while the other may not change at the same rate.
Old 06-29-2006, 02:51 PM
MattB
Support Corvetteforum!
MattB's Avatar
Ya, I have a Corsa catback and all its really for is looks and sound. You'll have more fun with good tires.
Old 06-29-2006, 02:53 PM
BQuicksilver
wrong Corsa system
Old 06-29-2006, 03:02 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,399 Likes on 749 Posts
Definitely option #2. Don't know what width is for front stock C6 (9.5?), but if the fronts are either 8.5 or 9.5, you can run 275 front/305 rear, a very nice setup.
HTH, and have a good one,
Mike
Old 06-29-2006, 10:25 PM
Blocktrdr
Blocktrdr's Avatar
Do not try option 1. Corsas do not have the cold grip that RA-1's have. Heated up they will be ccloser but cold might oversteer bad.
Old 06-30-2006, 06:20 AM
AU N EGL
AU N EGL's Avatar
option 2 dont mix tire brands.
Corsa 3" off road sounds great. Most guys here dont use mufflers anyway Just raz'n you. Welcome to the Light
Old 06-30-2006, 07:27 AM
0EG@EnglandGreen
Supporting Tuner
EG@EnglandGreen's Avatar
Location: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
To RA-1s on front and CORSA System on back?
Quick Reply: RA-1s on front and CORSA System on back?
