Harnesses
Old Feb 4, 2007 | 04:14 PM
threewinmag's Avatar
threewinmag
Default Harnesses
Who's harnesses do you use in DE's and why?
Old Feb 4, 2007 | 05:11 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
I started with Crow from DRM they re-web it for 40 bucks where Simpson doesn't do it for any price. HardbarUSA.com sell Team Tech which is real nice. I got the sternum strap also added when I sent it for rewebbing.
Old Feb 4, 2007 | 05:30 PM
gkmccready's Avatar
gkmccready
I picked up a TeamTech JetPilot from Hardbar. Very comfy. Very nice. And it works with the stock seats. It's really comfy compared to my old Simpson 5-pt.
Old Feb 4, 2007 | 06:52 PM
boerio's Avatar
boerio
I'm using G-FORCE 6pt harnesses with my Brey-Krause harness bar (w/ lap belt option). Working nicely for me.
Jeff
Old Feb 4, 2007 | 07:20 PM
johninar's Avatar
johninar
I have a Crow. I like the release.
Old Feb 4, 2007 | 10:45 PM
Lancer033's Avatar
Lancer033
I started out with a Crow, just replaced it with a Scroth built Sparco Harness. Haven't used the Sparco yet, but the main reason I got it was for extra room between the sub straps
http://sparcousa.com/pharness_comp.asp?id=370
vs
http://www.crowenterprizes.com/shop_...asp?sku=1114-C
Old Feb 5, 2007 | 07:38 AM
Maineiac's Avatar
Maineiac
From: Making my carbon footprint as BIG as possible
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude '03-'04-'05-'06
Schroth....
Old Feb 5, 2007 | 07:46 AM
AU N EGL's Avatar
AU N EGL
Look at several harness systems. Also take into consideration the seat you are using, do you use a HANS, and what are your mounting points?
YOur seat will determain if you need a 5 or 6 point ( two sub belts ).
Look at:
pull up lap belts, not pull down.
cam look over latch and link
chest strap
FIA certifications
Old Feb 5, 2007 | 08:29 AM
GO_BLUE_VETTES's Avatar
GO_BLUE_VETTES
I've got a TeamTech RamPac. Its a one part package that comes with lots of padding and a sternum strap. Very comfortable, more comfortable than a GeForce or Simpson setup I've ridden in. You can get custom color combinations as well (I did). CDOC.com stocks some colors for less than MSRP.
Old Feb 5, 2007 | 04:35 PM
Z06 Whisperer's Avatar
Z06 Whisperer
I've got a Schroth Profi II 6pt
Old Feb 5, 2007 | 05:58 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
TeamTech with a camlock. My car is my daily driver, and I where it all the time.
Old Feb 6, 2007 | 10:58 PM
Z06 Whisperer
I'm glad to see another person who uses their harness in their daily driver. My story's a bit different though because what I have in my daily driver is the 4 pt Schroth clip in for a BMW that I put in for the few high speed autox's I did with it, so it was an easy install and a very easy switch back and forth between that and the stock 3 pt. I just really find the 4pt Schroth so much more comfy!! No belt sawing my neck! I'm sure it looks a bit posey though!
I'm sure it would a redesign nighmare for car manufacterers, but would having a 4pt provide more driver/passenger safety?
Old Feb 7, 2007 | 02:55 PM
FasterIsBetter's Avatar
FasterIsBetter
Sabelt 6-point harness. Got it from Driving Impressions. I really love the cam locking mechanism. Works very well, good product IMHO.
Old Feb 8, 2007 | 07:51 PM
threewinmag
guys,
thanks for all the good information and helpful suggestions. I've finally decided on Corbeau 3" 5 points. These are in conjunction with A4's from Corbeau as well.
.300WM
To Harnesses
