C5 tire size question—just so I'm clear...
Old 07-27-2007, 02:18 PM
jpasterjak
jpasterjak's Avatar
Default C5 tire size question—just so I'm clear...
Yeah, I did a search, and I think I know the answer, but just so I'm completely clear before I start loosening nuts:
Will 18 x 10.5s with 315/30/18s fit at all four corners of a C5 without any issues? How about 345s in the rear?
I know some of you have this setup, but I wasn't sure if it was on unmolested cars or not.
J.G. Pasterjak
Grassroots Motorsports
Classic Motorsports
Old 07-27-2007, 03:19 PM
TommyBoy72
TommyBoy72's Avatar
I can't answer your question but this might help:
305/35/18 RA-1s fit without issue on a moderately lowered C5 Z06. This is on Stock C5 Z06 rear 18x10.5 wheels used at all four corners.
Old 07-27-2007, 03:25 PM
Adam Boca
Adam Boca's Avatar
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
I ahve a 2000 Coupe....running thin spoke Y2K rims...
10.5 inches wide....I have 295s on the car, not sure I would go bigger without going to Z06 wheels which people run 315s on..
This is just personal experience, never tried 305s or 315s...
Adam
Old 07-27-2007, 03:32 PM
AU N EGL
AU N EGL's Avatar
J.G. Pasterjak
Classic Motorsports
345s are too big and will stick why out.
335/30 x18 will fit but stick out about 1/2"
315s work up front too but again can stick out slightly.
StArrow68
StArrow68's Avatar
Stock thin spoke C5 wheels are 18/9.5 and the Z06 wheels are 18/10.5.
295s will fit on the thin spokes but are standard size for the Z wheels.
Just for info, I run 17 275/s in front on a 2002 coupe w/Z size 17/9.5
wheel and that scrapes my brake duct extension, ACI, if I remember.
Randy
Old 07-27-2007, 03:46 PM
jpasterjak
jpasterjak's Avatar
That's what I figured. I just tried my 315s on 9.5 inch wheels on the front and didn't see anything close to being an issue. I can't imagine the 10.5 wheels would be any worse. Having the ability to rotate the tires would be sweet, too.
J.G. Pasterjak
Classic Motorsports
Old 07-27-2007, 04:18 PM
TommyBoy72
TommyBoy72's Avatar
J.G. Pasterjak
Classic Motorsports
That was the idea, four tire rotation. The offset of the Z06 rears does put them out quite a bit but I have no rubbing on the front even running on a banked track.
Old 07-27-2007, 04:23 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Rule of thumb is to have 1/2 wider wheel track up front. When you go to a larger rear wheel this is hard to maintain.
Randy
Old 07-27-2007, 04:29 PM
TommyBoy72
TommyBoy72's Avatar
Randy
Can you elaborate on this? I'd guess the track width of the front is about 1/2 to 3/4" wider that it was stock. Since I changed the wheel size and tire size at the same time I cannot conclude exactly which had the greater effect but the stock steady-state understeer I was dealing with disappeared on the track.
To C5 tire size question—just so I'm clear...
Quick Reply: C5 tire size question—just so I'm clear...
