help me pick a vette
Old 09-17-2007, 05:47 PM
redtopz
redtopz's Avatar
Default help me pick a vette
I have been getting into autocross this year and want to buy a vette within the next month. I also do an occasional drag race and would like to try road racing, but primarily autocross and weekend cruises. I am trying to decide between a 04 z06, a 06 zo6, or a 08 z51 c6. The c5 zo6 might be the best choice, but I like the newer improvements/interiors of the c6's. The new z06 might be geared a little too tall for autocross. The 08 z51 might be a good compromise although it is a little heavier. I am not afraid to modify my cars a bit with suspension, headers, cams, tuning, etc. Any advice would be appreciated I am having a hard time making a decision .
Old 09-17-2007, 05:50 PM
AU N EGL
AU N EGL's Avatar
the C5Z06 is pure and simple, GRUNT. Raw power to get the job done PERIOD.
Old 09-17-2007, 06:03 PM
Carolina C4 Racer
Carolina C4 Racer's Avatar
True, but if money matters the 04 Z06 is a steal at less the half the price of an 06Z & probably just as good on an autocross course.
Old 09-17-2007, 06:08 PM
TedDBere
TedDBere's Avatar
When I had to decide, I knew what to buy...
Old 09-17-2007, 06:55 PM
redtopz
redtopz's Avatar
Right on guys . Its hard to find a negative with the c5 zo6. Its cheaper and just as fast if not faster than the c6's in autocross. I can't wait to get some wide *** tires under me. I've been driving a modified gto and its fun but the tire width is limited to 245 or 255.
Old 09-17-2007, 06:58 PM
John Shiels
John Shiels's Avatar
Location: Buy USA products! Check the label! Employ Americans
c5 and then you have mod money
Old 09-17-2007, 08:01 PM
fhturner
fhturner's Avatar
I'm kinda partial to the C5Z's bang-for-the-buck advantage, too, but the ability to take the top out for crusin' in the '08 Z51 Coupe is a very nice feature you won't have w/ either Z06. Since your focus is more autocross and cruisin', I think the '08 gains a bit of an advantage. If you were leaning more toward road racing, then either Z06 would definitely gain points, perhaps the C5Z if cost were an issue (or if you wanted $$$ left over for mods, as John says)...
Whatever your choice, though, you can't lose!
Old 09-18-2007, 02:58 PM
asp04
asp04's Avatar
Default my choice
If I had the resourses to consider a new z06, and autocrossing was a big consideration, I would by a c6 z51 automatic, decked out with all options available. I would just keep it for the street and occasional HPDE. Then with the savings, I would by a 1990's miata and run in sm2 or I think it is stx. Most courses are not large enough for a corvette to show its capabilities. I am soon to practice what I preach. Having taken 2 new corvettes and run'em hard, blasted the paint off the lower side, and set em up to ride like a 1-ton truck. My next will be a nice car to hotrod around in, enjoying all the bells and whistles, and keeping it nice. As for the miata, I plan to set it up to ride like a go-kart, boost it enough to feel like a vette on the straights, and hammer it with no regrets.
You know, it is awful easy to advise others how to spend their money.
Old 09-18-2007, 11:40 PM
redtopz
redtopz's Avatar
Those are all good ideas. I'm still wavering but I might pull the trigger on this 02 zo6 :
http://forums.corvetteforum.com/show....php?t=1815465
I figure if I want to autocross and road race, might as well pick the right tool and not compromise. I'll still have my goat for cruising
Old 09-18-2007, 11:47 PM
codysdad
codysdad's Avatar
Default Already modified!
Go with the used LG number 28 It might be 180,000 but you could probably get it for 179,000. Friken awsome car! Check the c-6 sale adds Sorry I had to say it I can't get over the car is for sale.
Old 09-19-2007, 09:17 AM
AUTO_X_AL
AUTO_X_AL's Avatar
I think the 08 Z51 is a great car. My big thing about that car is the 8.5'' front wheels. The C5Z has 9.5'' fronts as well as the C6 Z. If you care about classing this is a huge deal. If you don't go buy a set of CCW's and some stickies and go run. The 08' really is a very nice car though. The extra 36 HP is pretty evident.
Good luck. It sounds like whatever you get you'll have a nice car.
Old 09-19-2007, 02:31 PM
racerwannabe
racerwannabe's Avatar
St. Jude Donor '06
i have an '02 ZO_6 for sale..save money and have a proven car to start with..lg long tubes, x pipe 4 way motons,hardbar camber kit and 5 point harness,carbotech pads,braided lines,,center aluminum plate,kirban shifter,variram..tuned..ready to go.still tagged and street driven...reason?? i'm gonna concentrate on the red car with the big engine
Johnny
oyea,black black and a spoiler
Old 09-20-2007, 11:03 PM
redtopz
redtopz's Avatar
That car sounds good, but I'm across the country in california.
Old 09-24-2007, 03:35 PM
racerwannabe
St. Jude Donor '06
with the money i'll save you .you can fly here and pick it up ,drive it home,, if we take the camber out ,,and have money in the bank..
Johnny
Old 09-24-2007, 05:49 PM
MungoZ06
MungoZ06's Avatar
St. Jude Donor '10-'11
Well, I slept in a Holiday Inn Garage last nite and have a few minutes, so here are my free thoughts:
AutoX, Drags, "road racing" ... Open/Exhibition, or Sanctioning Body Competition? The choices would fall into different classes. Do you want to go out for fun, or to compete?
All will do fine, but to be competitive you'll have to mod within class limits. Suspension settings are usually allowed ... but at compromise of "streetability" on a dual use car.
Corvettes at drags usually mean hardened output shafts, diff braces, if run with anything like power mods OR anything like Drag rubber ... again ... mods ... also prolly want diffferent suspension settings from "road racing"
HPDE events (non-competitive) or Time Trials or W2W competition? Same comments as AutoX, and there's a progression of mods, depending on how hard, how frequently, and how seriously you pursue.
Any suspension mods for track events will take you away from optimal street settings. Some seek a "compromise" configuration that sacrifices street comfort and track performance.
It comes down to money and objectives.
As for gearing ... true ... C6Z is a bit "taller" ... but in my observation, the challenge is using the power smoothly and maintaining traction at the limits of adhesion. ... again ... if you're competing ... class classification put all in same plane.
JMHO ... HTH ...FWIW ... YMMV ... (usual disclaimers )
To help me pick a vette
Quick Reply: help me pick a vette
