Hey racers... neet to lock in a bolt head on my seat rail that won't be accessible.
Old 01-28-2008, 03:27 PM
Cobra4B
Cobra4B's Avatar
CI 3-5-6-7-8 Veteran
Default Hey racers... neet to lock in a bolt head on my seat rail that won't be accessible.
Installing the ultrasheld in the panoz using the Hardbar seat mounts I had for the corvette. Had to drill new holes to meet up w/ the panoz chassis and the rear bolt heads are not accessible with the seat in. The bolts go down through the frame and use a lock nut under the car.
So.... I need to bolt heads tacked in place so I can tighten the nut on them. The seat rails are aluminum. A local body shop near me didn't have the rigth welding rod and the weld he tried popped right off.
I need this back bolt to be locked in place before I put the seat in:
I got some of this Permatex metal epoxy:
Would it work? Or shold I take it all to a shop and have them weld 2 strips of aluminum plate to either side of the hole so when the bolt head is in place it cannot turn?
Thoughts? I figure if a Lotus Elise's chassis is all bonded/glued together that the right stuff shold do the trick, no?
Old 01-28-2008, 04:11 PM
VetteDrmr
VetteDrmr's Avatar
Received 1,399 Likes on 749 Posts
The problem will be similar to the weld problem you experienced: getting the epoxy to hold. You'll have to rough up the metal, which always puts stress risers in the scratches. Might not be a problem but.....
I like your thought of having two aluminum plates capturing the bolt head.
Good luck, and have a good one,
Mike
Old 01-28-2008, 04:15 PM
RAFTeRACER
RAFTeRACER's Avatar
You could use a slightly larger bolt and tap threads in the seat mount.
Old 01-28-2008, 04:17 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
There is no welding rod in the world that will hold aluminum and steel together.
Randy
Old 01-28-2008, 04:19 PM
Cobra4B
Cobra4B's Avatar
You're a smart'un.... good idea.
Old 01-28-2008, 04:23 PM
gkmccready
gkmccready's Avatar
But you could put a blop of rod next to the head of the bolt to keep it from spinning.
Can you reach under with a flat head screwdriver and just jam it against the bolt head to keep it from spinning?
Old 01-28-2008, 04:24 PM
Cobra4B
Cobra4B's Avatar
I think I'm going to try the epoxy tonight and see what happens... I'll let it cure and install the rail in the car w/o the seat to see if it holds. If it doesn't then no harm no foul and back to square 1.
Old 01-28-2008, 04:25 PM
Cobra4B
Cobra4B's Avatar
No... once the seat is in, the bolt head is not accessible, the front is, but the rears are completely blocked.
I like the idea of 2 blobs of aluminum weld to capture the bolt head and stop it from turning.
I think the epoxy might work then... I'll epoxy the bolt head then lay it around the head to act as a barrier.
Old 01-28-2008, 04:26 PM
Oyishdog
Oyishdog's Avatar
Randy
Also, put some silcone or something between the two metals...over time the two will begin to corrode
Old 01-28-2008, 04:34 PM
Cobra4B
Cobra4B's Avatar
Thanks for the tip... going to try the epoxy tonight... will report back.
Old 01-28-2008, 06:03 PM
MAC95 6SPD
MAC95 6SPD's Avatar
The bolt is not accessable after the seat is in but do you have to bolt the seat rail in first. In the C4 I have the same problem. I fixed it by bolting the seat to the rails while in the car. I could rock the seat back far enough to get to the bolt head and tighten the bolt. Then the seat and the seat rails would bolt to the floor last.
Mat
Old 01-28-2008, 08:03 PM
mountainbiker2
mountainbiker2's Avatar
Hacksaw a groove in the end of the bolt. Hold it with a screwdriver when you tighten it.
Steve
Old 01-28-2008, 08:09 PM
trackboss
trackboss's Avatar
On bolts I can't access with a wrench I drill a hole in a piece of strap or use a small round rod and weld onto the bolt so that it hits something when turned. It's really pretty simple. The tack next to the bolt head is not reliable.
-V
Old 01-28-2008, 08:43 PM
0Randy@DRM
Former Vendor
Randy@DRM's Avatar
Brian,
This is what happens when you try and install Corvette parts in a Ford Sorry I couldn't help myself.
A old farm trick may work for this also. Use a very skinny needle nose vise grip. Grab the top portion of the exposed threads and use a socket to tighten up to the vise grip. Then use a wrench to tighten the nut, and use the vise grip on the bottom. Disclaimer: Farm tricks some times aren't the best or safest method.
Randy
Old 01-29-2008, 02:08 AM
Cobra4B
Cobra4B's Avatar
Ghetto modding worked Used the Permatex Metal Epoxy
Tested it and torqued it before putting them back on the seat to see if the epoxy would hold.
Seat back on
Installed along w/ fresh harnesses and some fresh interior paint
Old 01-30-2008, 09:55 AM
Slalom4me
Slalom4me's Avatar
Why not just make one or more access holes in the seat?
Depending on size and location, the holes can be left open, sealed
with duct tape, push-in rubber panel plugs or an access plate afixed
with one or more fasteners in such a way that they won't be felt while
seated.
Old 01-30-2008, 09:57 AM
Cobra4B
Cobra4B's Avatar
^ Never even thought about that... that's a great idea.
Old 01-30-2008, 12:45 PM
Slalom4me
Slalom4me's Avatar
Works on my Kirley Deluxe RR.
To Hey racers... neet to lock in a bolt head on my seat rail that won't be accessible.
Quick Reply: Hey racers... neet to lock in a bolt head on my seat rail that won't be accessible.
