Brakes for C5Z, occasional track and autoX
I have ordered Hawk HP plus pads.
I would like opinions on rotors to match these and resist warping on a technical circuit with lots of accelerations and decelerations.
A. 1. I could stay with the stock rotors, go to 2. slotted Sport Brembos or
B. go to cryo treated rotors, such as 1. Cryo-Stop, 2. cryo-treated Power Slot or 3. Frozen Rotors.
Based on my limited reading, cryo-treated Power Slot rotors seem good.
I have not considered 2piece rotors very seriously due to cost.
I would appreciate input on the rotors, as well as compatibility with Hawk HP Plus
MK
MK
St. Jude Donor '08
Just my opinion. If you are just beginning, for occasional track use, go with the ZO6 pads and stock rotors. Change the brake fluid to a high temp one and go from there. This equipment should serve you well as you progress in your driving skills. There are quite a lot of more experienced drivers on here that will probably offer further help. I've been going to the track for a year. This is the way I run my ZO6.
Gene
Gene
Having gone through 2 sets of rotors just with spirited back road driving when the car was stock, Frozen Rotors where the best mod I did to my stock brakes - followed by stainless steel lines and Hawk HP+ pads.
I presented the GM area rep with a set of stress cracked stock rotors in 2002 - from 3000 street miles with stock pads - the bottom line is the will crack, it is just a matter of how long they last.
Going Frozen Rotors almost tripled my mileage on stock sized solid rotors.
Hawk HP Plus pads with stock rotors?
In the short term I'll stay with stock rotor and pads, braided brake lines and higher boiling point brake fluid.
MK
RC45's experience is pretty unique. I've run 70,xxx miles on my current set of rotors (changed them at 100K because, well, just because ), and I've gone through several seasons of autocross and occasional track usage with nothing more than the harmless spiderweb-look cracks in the rotor surface. Once a crack grows to the inner or outer edge of the rotor (stock or slotted rotors) or connects two drilled holes (for drilled rotors), the rotor is junk.
Do a search on cryo-treated rotors; you'll find much debate that there's no point re-writing here.
I've been running PFC Z-rated pads, which are similar to HPS + pads or Z06 pads in performance. I've never had a rotor "warp" (which is primarily brake material deposits on the rotors for a variety of reasons) on my Vette. I've had rotors vibrate almost out of the box on other cars. Point being that stock rotors are just fine unless you go with a big brake kit.
HTH, and have a good one,
Mike
Mike
I would go out on a limb here and say 100,000 miles on a set of OEM C5 front rotors used on race tracks and autox is the unique experience.
I am not interested in getting ino a pissing match, if yougot 100,000 miles more power to you.
The OP asked whether cryo treated rotors were a good idea, and I offered him an opinion.
Keep the shiny side up and keep hitting your apexes..
Peace.
Peace.
We have a technical track at Calabogie with lots of decelerations to low speeds and brakes get very hot.
MK
I've used Hawk HPS pads on my C5Z06 and C6 coupe and they offer a nice increase in grip over the stockers and have very nice (i.e. stock) warm up characteristics and the dust is no worse than stock.
I'd use these for the street and switch to a race pad when racing.
1 Post
Rock Auto rotors with BHP race pads. http://bhpbrakes.com/ talk to Matt this is an alternative to Hawk which I have used. SS brake lines and good fluid and try GS610 brake fluid from BHP Rotors are disposable depending on your driving technique and track the life of your brakes will vary.
MK
MK
Again the rotors,
NAPA or Raybestous part #s
86700
86701
86702
86703
or the Rock Auto Raybestous part #s
56700
56701
56702
56703
Good DOT 4 brake fluid, Motul 600, ATE Super Blue or Gold 600, Castrol SRF. Many guys have had good luck with Castrol LMA and Valvoline Sythtec
Brake pads
Hawk HP+ will get you though one maybe two days. then you will need to change brake pads.
Good track pads no order
Wilwood H
Hawk DTC-60
Hawk DTC-70
PFC-01
PFC-05
Carbotech XP10 to XP12
The Carbotechs can be driven on the street somewhat. The others above should not be driven on the street. They can but will squeek like the blazes
Good Luck
I wonder if people can confuse runout with warping. Can unequal lug nut torque cause physical runout on the metal of the rotor, not from deposits?
One weekend at Road America:
200 miles on a set of rotors is good, right?!?!
Received 8,928 Likes
That being said it is still wise to torque the lug nuts evenly as this ensures the wheel is held on properly and there are no unusual strains being applied to the wheel when cornerng, etc.
Bill
http://forums.corvetteforum.com/show....php?t=1673518
Have a good one,
Mike
The crack in the middle is deep enough to catch my nail on. I thought it could be run a little more as well but didn't want to have to work on the car at my next event. The NCM RA event is getting close and I'm just about prepped!
Former Vendor
There was an SAE paper some years ago that indicated that in fact unequal torquing of the free fitting hat/rotor can exert some deflection in the rotor. You can probably do a search for it but not read the whole story without paying for it. I confess I remain a bit skeptical on it as well but the did show some minor alterations from this.
And for the record, I doubt you will find many other C5's with stock rotors lasting 75 to 100,000 miles if the car is autox'ed or tracked at any level of aggression.
I run the stock rotors pretty hard and they seem to last just as long as the expensive rotors.
If your rotors last 100,000 miles of track use, you aren't braking hard enough.
