Brake Vibration...recommendations please
I recently cracked one of my C6Z rotors at the BMW weekend (3 days) at NJMP. At the track in between sessions, I changed out the rotor with a spare I had brought. I went out to the next session and really didn't follow the bedding instructions like I should, and as the day progressed, I had a slight vibration under only the hardest braking zones. I usually bed my pads around my house stricly following the procedures before the event, but on the track, I was just not able to follow the bed in procedure as strictly as I normally would.
I am thinking the vibration is pad material put on the rotor unevenly due to the improper bedding. I hate to throw away a new rotor, is there anything that can be done to save the rotor? Will a few more sessions potentially clear the situation up? Can I try to rebed the pad on the street or have I done irreversible damage?
I've had this happen countless times. I usually just deal with the vibration until it becomes too much, then scrap the rotor. I have heard that you can take a scotch pad on an angle grinder to try and get the pad material off of the rotor, but have not tried it myself.
Until the Corvette I always ran Hawk Blues (on lighter cars) and they eat more rotor than pad typically so I've never had to deal with this issue personally.
CF Senior Member
