Jacking up a C4
So threepoint - whatcha gonna do with that c4??????
You'll find me at Road Atlanta in a couple weeks with NASA-SE!
I'm still gettting used to it. Friends are trying to get me to go to "import showdown" (drag). I keep telling them..."It's a chevy"..."God Bless America"!!!
I'm still getting used to it's limitations and frankly, "Mine". I'm honestly trying not to break it...lol.
I'm sure I'll be more comfortable with it in a while. My daughter says I'm going to get into trouble with it. I told her, I'm just testing it..."that's all".....snicker snicker...
Received 8,960 Likes
I think the markings for jacking point changed over the years. I had an 86 that I sold 19 years ago but I remember jacking on the flange between the two marks. The black plastic edge would crush and then straighten out. I jacked it like I did my 69, 71, 97, 03 and 08. Lift the one corner high enough to take both wheels off the ground on one side and if I wanted jackstands on both sides of the car I would jack it high enough so it was only resting on the jack and one rear wheel. Then I would place my jackstands, move to the other side and use the jack to level the car and adjust the jackstand height on that side.
Bill
Bill
Received 1,773 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Bill
Bill
Yep, no way to get a jack under the air dam.
Now once you have it up in the air you can jack from a center point along the front frame rail.
When I need lots of space I do both sides till its level, then get out the big jack and lift it to the height I need, gotta watch the exhaust though.
If I need tons of space I get the rear up a little as well. Its a lot of side to side, then back and front till I get it to the right height.
Next garage will be tall enough for a lift.
The AIM manual says to place a floor jack under the front center of the car between the drive train and front suspension frame between the two front wheels. Why is this subject so complicated? I've been reading posts for hours now and everyone has a different opinion.
Is the manual incorrect?
