Drifting in a C4??
Drifting in a C4??
Hey guys i was wondering if any of you take your corvette to the track and drift? I had a 90 camaro with a 305 and got decent then now i have a 86 corvette Z51 w/ 4 speed and its so much easier and everything is really smooth.
Do you guys think corvettes are good drift cars?
kevin
kevin
Well, in a word, no...
For a drift car you want something that understeers like a pig so that you can break the back end loose with power and still have some stability margin. A Corvette has more weight on the back wheels and consequently it puts down more power rather than breaking the back end loose...
If you wanted to, you could try to put in huge bars in the front, and take off the rear bar and, if you didn't put big tires on it you could drift it some, but there are a lot better cars to start with (like a Camaro or Fox body Mustang or GTO) that don't have as much weight on the rear wheels, are cheaper to buy and, since they have a beam axle are cheaper to maintain than a Vette....
firstly, drifting is stupid. Now that that is off my chest...
the dumbasses that I know who drift say the vette doesnt have enough steering angle. So unless you're going to dive into the knuckles/steering apparatus and fab up something custom... it wont work.
Received 1,769 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
This is more like real drifting. Danny Popp Style!
http://forums.corvetteforum.com/auto...-possible.html
The second part is right, most people stay away from them because of their lack of steering angle.
I would have just used the Camaro. I have no experience with setting up a C4. Hopefully some brave soul would chime in instead of just saying how much they hated drifting.
Received 8,958 Likes
Bill
I'm actually going into drifting. Nothing serious or competitive, I just want that set of skills. I found that it is a very difficult for me to learn drifting. I have to throw out all the things I have learned over the years in autox and some very limited exposure from a brief HPDE event.
Most racers look down at/hate drifting due to its judged events, but the skills are still there to learn. Controlling/balancing a car at the verge of instability is not natural to me and it's been a very frustrating and exhausting learning process. This is even worse than going from racing an AWD to a very powerful RWD.
I don't think massive steering angle is required in drifting. It's nice so the car can slide at larger angle that will wow the judges, but it's not everything. Answering AU N EGL question, there are practice events set up in almost every state. These events are usually at grass root level. The ones in my state are organized and run by an import speed shop in Dayton at an oval track with infield. National events are like Formula D but I have no idea about those.
As with most motorsports, if you properly set up the car for the sport it gets an awful lot easier. When I was a kid I had a BMW 2002 and my best friend had an MGA. We could take both cars out on the back dirt roads and the MG was a breeze to drift around in lurid slides, while the Bimmer was like balancing on knife edge. One slight wrong move and you were visiting the tulips... Same thing in ice racing, some cars can be hung out for miles while others you have to keep absolutely in line or you are gone.
The setup for drifting involves big push, and other than using it for drifting, the car is pretty much worthless for anything else. If you set your car up that way, yes you can learn to slide it around, but the car control skills aren't really going to transfer over to the track because track cars don't respond the same and you are more likely to end up doing a tank slapper if you try to recover a real car the way you do a drift car...
Adding more steering angle shouldn't be too difficult. Just fab up a new mount to shorten the steering arm. It will give you a quicker ratio and more angle. Bolt on some 225's and you should be sliding all over the place.
Once again i dont really drift. Me and some buddys will go to a big empty parkin lot and have cones set up and i could drift so much better in my c4 then my camaro. I dont know if that Z51 stuff had anything to do with it? then it also has the low end to make quick and easy around a turn.
Just thought i would ask how many of you guys do it and how good are you with it?
kevin
kevin
