E85 at Road Courses?
Thanks,
TJ
Bill
-TJ
-TJ
-TJ
Ive got that 5 chip program in one chip with the turn of ****. So far, Ive only tuned the one chip as my 427 passed emissions better than my 350 with zero knock, so far.
Thanks for the info.
-TJ
I brought Nick my 2005 gto I just built up with a F1A procharger and a fuel system designed for E85. He expected 700 rwhp out of it and it ended up with 761 rwhp. E85 kicks butt in a F/I engine. If you run it in your track car get ready to burn through a ton of fuel (about 30% more than gas). You could always make your own blend of E66 or E50 if you wanted. It would probably protect your engine better than race gas.
Wouldn't something VP C10 or StreetBlaze 100 be better choices? Both have a 100 R+M/2 rating with a mixture ratio closer to pump gas.
That's a start...
E85 actually has more power potential, though it does indeed require more fuel (though not nearly twice as much, somewhere around 30-40% for stoich but less than that at peak power).
Yes, I could probably make more power on "real" race gas, like C16. But E85 also costs about $0.20-30 LESS than 87 pump gas. As stated, the motor will use a lot more E85 though. So call it a wash on cost/mile vs. 91 pump. Also, I can get E85 at the pump easily locally (my Z is still street driven). So when I compare E85 to gas, I'm really comparing to 91.
So anyway, the overall benefits would be...
- More static compression - we're looking at around 12:1
- More dynamic compression - we can spec a cam which builds more dynamic compression
- Cooling effect - E85 provides a marked cooling effect which both provides for a cooler running motor (will be nice during 115* F days at THill) as well as allowing for more timing
- Cleaning - E85 keeps injectors super clean, and cleans/prevents any carbon buildup in the engine
Downsides...
- Availability - this is the big one: it'll probably be a few years 'til it's readily available at the track. That means taking in a few drums on the trailer. Ack.
- Fuel mileage - people actually report much less fuel mpg loss than the theoretical 30-something % extra required fuel. With the extra timing E85 allows, quicker burn, etc. the extra torque might allow lower throttle positions for the same driving conditions, making back some of the mpg.
- Smell - I haven't actually smelled it yet, so IDK.
Lots to think about.
-TJ
Obviously this doesn't directly translate to our motors but the air fuel ratios do.
Here's a link about the team:
http://gmtunersource.com/index.php/b...werboat-racing
"I stumbled over this while searching for something else.
Materials that have performed well in E85 systems include, but may not be limited to, those listed below. U.S. Department of Energy
Metals:
Unplated steel
Stainless steel
Black iron
Bronze
Non-Metallic Materials:
Teflon
Nitrile
Viton
Polypropylene
Buna-N
Neoprene rubber
Non-metallic thermoset plastics
Thermoset reinforced fiberglass tanks
Thermo plastic piping
DURABILITY OF VARIOUS PLASTICS: ALCOHOLS VS. GASOLINE (Mother’s Alcohol Fuel Seminar)
-----------------------------Ethanol----------Methanol------------Gasoline
Conventional Polyethylene-good------------excellent-------------poor
High-density Polyethylene-excellent---------excellent-------------good
Teflon---------------------excellent----------excellent--------------excellent
Tefzel----------------------excellent--------excellent-------------excellent
Polypropylene--------------good------------excellent-------------fair
Polymethylpentene---------good------------excellent-------------fair
Polycarbonate--------------good------------fair-------------------fair
Polyvinyl Chloride-----------good------------fair-------------------poor
Excellent: Will tolerate years of exposure.
Fair: Some signs of deterioration after one week of exposure.
Good: No damage after 30 days of exposure, should tolerate several years of exposure.
Poor: Deteriorates readily.
NOTE: All tests were made with liquids at 122 deg F.
Compare Gasoline to Ethanol and make your own decision."
-TJ
Anyway, I take the above with a grain of salt, because EITHER organization is encouraging E85 and has a vested interest. That being said I did a fair amount of reading over at ls1tech and there are lots of people with several years of E85 in there LSX vehicles without issue. Obviously that real-world data is the most valuable.
-TJ
