Question for guys who record track videos - (VIR clip also)
http://www.youtube.com/watch?v=dTNLwoskdAo
In the past I've had good luck with a suction cup type (3point) mount for my windshield. Wind noise is low and there is nearly 0 vibration.
I threw raceseats/harness & a hardbar in with a nice short aluminum mount. The recordings arent nearly as good as before. My panasonic DMC-ZS3 has wind cut and stabilitzation but apparently its not enough under these conditions!
Is there some sort of magical seceret to cut back on the wind noise and stabilize the camera at 100~150mph when mounting to a hardbar? I even tried sliding it near the passanger seat to reduce on the harmonics of the car and block it from the direct wind. (that video is above.) Visually its not so noticeable in low-res. Crank it to 720 full screen and its evident at high speed.
as far as "whiteout", I have the same problem with my setup - there is too much black interior in the picture and camera autobalances the brightness. if you can change FOV, turn off autobalancing the brightness/colors or move camera close, it will help a lot.
i kinda like it! makes you feel like your going fast ! try taping a small foam rubber over mic hole and using a softer rubber base under the camera. also turn off auto focus and turn down the white settings. try using different presets in the camera. the sport setting might be good. trial and error are your friends! G/L nice driving
Your right, moving it close has worked with the suction mount. What's FOV?
I run a panasonic, on a roll bar, and all I do is put painters tape over the mic and it seems to work well
http://www.youtube.com/user/PAZ06200.../3/5EAc0cDaKaI
EXCELLENT VIDEO
WHAT ARE YOUR SETTINGS IN YOUR CAMERA
I'm willing to bet it's your mount. Somehow, there is movement and a different frequency between the car/bar and your camera.
And turn off the stabilization...most camera stabilization cannot keep pace and it causes more issue than it's worth.
Good luck.
Good luck.
My video cam went bad, so for the Tues session there I used my Canon Coolpix camera mounted on my harness bar. The video was adequate, and I really liked recording straight to sd card, but the wind noise was horrible. Ordered the Aiptek HD w/ wide angle lense to use at VIR next week. I think I will try to find the remote mic addon. Strangely, the Cool Pix picture went blank about 15 seconds before I spun in turn 4. Half way thru the second 360, the video reappeared. During the "blackout" there was still sound, just no video - odd. It was the only time in 2 hrs of recording that that happened. Wife says that if I looked at my watch, it probably had stopped also (she thinks car is cursed).
Received 3,805 Likes
"Ask Tadge" Producer
- Wind noise
- Engine noise
- Sound Clipping
Listen carefully right when your video starts off. You can hear the wind whistling by the camera. As you round the first corner, you can barely hear the engine start to rev. The faster you start moving, the louder the third noise sounds. That third noise is the system clipping the sound.
How to fix? Well, you can experiment with external microphone placement. Some of the best spots I've heard are actually buried under the carpet in the rear hatch.
My solution is a second device. I use a Roland R-09 digital sound recorder. It has the apropos circuitry to deal with the sheer volume of... noise. I keep it in my glove box, with its external mic sitting inside the center console. When I start camera and Roland recording, I loudly clap my hands once, on camera, so that I have a sync marker. When I get home later, I spend the time and merge the two together. It does take a bit of time, but it's actually pretty fun to do.
Plenty of old examples here: http://gallery.lateapex.net/main.php/v/movies/
jas
