Reusable track car numbers?
Old 06-09-2010, 07:22 PM
thisismyusername
thisismyusername's Avatar
Default Reusable track car numbers?
So I've been using good old fashion painters tape for my numbers for HPDE events, but was thinking of something that looks a little nicer. For the group I run with, car numbers have to be 10" and on both doors of the car. I'd like something I can reuse.
What do you use for car numbers? I need something I can take off after events and reuse.
Thanks.
Old 06-09-2010, 07:30 PM
c4cruiser
c4cruiser's Avatar
I had a local graphics shop make up a set of static cling numbers. I needed numbers 8" high and they made up a single clear vinyl sheet with the numbers printed on the inside of the sheet. They let me select any Windows Tru-typ font they had and a choice of about 12 colors.
The sheet came on a plastic-covered backer sheet that hold the number set when off the car.
To affix the numbers, I squirt a film of water on the door, lay the sheet on the water and squeegee out the water. That holds the sheet to the car door and I can even use them for track days without then coming off.
You can get static clings from SoloTime or iZoom graphics
Old 06-09-2010, 07:34 PM
froggy47
froggy47's Avatar
www.squierdesign.com
Old 06-09-2010, 10:01 PM
Charley Hoyt
Charley Hoyt's Avatar
Here are some pictures of mine. I ordered them from Zoom Graphics.
Old 06-09-2010, 10:37 PM
bearnest
bearnest's Avatar
David Farmer here on the forum.
Old 06-09-2010, 11:38 PM
naschmitz
naschmitz's Avatar
Reusable vinyl from www.izoomgraphics.com
Old 06-10-2010, 12:23 AM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
Don't buy the magnetic numbers.
There's a vendor at NASA events in Arizona who cuts numbers/letters on-the-spot (or, if he's busy he'll send them to you). He has his whole print shop setup in his trailer. The graphics are nice and the prices are very reasonable. I'm not sure if he has reusable media or not. His web site is:
www.twistedpriorities.com Look for the Graphics Guy link.
Old 06-10-2010, 06:17 AM
GO_BLUE_VETTES
GO_BLUE_VETTES's Avatar
Old 06-10-2010, 06:53 PM
brkntrxn
brkntrxn's Avatar
David Farmer on this forum.
Old 06-10-2010, 07:02 PM
Richor
CF Lifetime Member
Richor's Avatar
Thats where I got mine.
Old 06-10-2010, 07:39 PM
davidfarmer
davidfarmer's Avatar
reusables look nice, but you must take care to keep them clean. They won't last forever, but with care you can get several events out of them. I can do solid black or white, or layer any color over them, and pretty much any windows font, size etc.
Old 06-10-2010, 08:08 PM
Richor
CF Lifetime Member
Richor's Avatar
I have used mine 3 events already and they still are almost like new. Thanks David
Old 06-10-2010, 08:15 PM
mousecatcher
mousecatcher's Avatar
i like the water based spray paint and number stencils. looks great and just wash the car after the event and back to brand new.
Old 06-10-2010, 10:19 PM
waktasz
waktasz's Avatar
I get a set of low tack vinyl numbers every year from http://www.ssc-tint.com/
We run 20+ autocross events a year and because I'm a clutz I occasionally rip one, but other than that, they easily last all season, and more if I didn't like changing things up.
Old 06-11-2010, 09:12 AM
AverageVetteNut
AverageVetteNut's Avatar
Cruise-In 9-10 Veteran
CI-X Auto-X Champ (race tires)
St. Jude Donor '07-'09
I used the "re-usable adhesive" #s from solotime last year for autocrosses and they work great but don't last forever. I didn't get a full season out of them, but it was a rainy autocross season.
I went for the static clings for nationals and I lost the '1' on both sides before my morning runs were gone.
Since then though, the other numbers have held up great.
Old 06-11-2010, 09:55 AM
lbarnard
lbarnard's Avatar
http://www.gochecker.com/StaticCling_album/index.html
Old 06-14-2010, 04:14 PM
JohnD60
JohnD60's Avatar
My avatar shows my attempt at low cost removable numbers. It is adhesive backed 8 1/2" X 11" paper from Walmart with numbers printed by my home computer printer.
Worked well (surprisingly even in the rain). However, in the end I realized the ink cost was more than buying numbers.
John
To Reusable track car numbers?
Old 06-14-2010, 10:03 PM
davidfarmer
Contact Paper is still a favorite of mine, although real vinyl is about the same price. Before I got my plotter, I used to keep templates (printed from my PC) rolled up in the roll, and I'd just cut a new set out with scissors before each event. Looked great, and worked well.
Now I use removables some, sometimes I just cut fresh vinyl to fit my mood!
Old 06-14-2010, 10:23 PM
shakedown067
shakedown067's Avatar
St. Jude Donor '12-'13
I had david cut a set of round decals on removable vinyl for a friend of mine. He's used them for two events and they are still like new.
Old 06-16-2010, 08:00 AM
davidfarmer
I've more-or-less figured out what does, and does NOT work, with removable now, so drop me a line if you need anything. I also have a roll of magnetic that I bought for a customer, so keep me in mind that you ever need that as well.
Off to CMP for a long weekend to try out MY new numbers! Orange over black removable...
Quick Reply: Reusable track car numbers?
