Racing Seats for Bigger Guys?
I have the Corbeau A4's standard size (that's all that will fit) in my 1990 C4. I am 6'3", 265lbs, 40 waist. They fit great, feel great, and hold great. I bought mine to lower my seat height a couple of inches below stock so I could drive with the roof on at track day events. My drivers seat (which is really a passanger seat as the A4 mounts opposite to clear the recliner handle) is shaved 1" and has the subbelt cutout for my 5 point harness. Great fit, very comfortable. I have the black fabric, double locking slider and set up for 5 point harness. My car runs the glass top which gives me a couple of inches extra headroom as well.
I can't speak to durability, but I can say new the product is sharp, and the factory is very responsive to questions. Also service was good, they sent me the wrong mountings, and had the right ones to me within 36 hours of being called.
18" Kirkey Intermediate Road Race Seats in C6
These are 18" Kirkey Intermediate Road Race seats on Hardbar seat rails with the TeamTech Jet Pilot harnesses. I'm 6'1" 245lbs and these seats are a little roomy in the bottom but are a really nice fit in the shoulders for me. Replacement covers with new foam are relatively cheap, so I can experiment by adding some foam to these covers where I need it.
The Kirkey seat rails are so short there is no way you could use the stock seat studs with those, so buy the Hardbar rails.
How much head room did you pick up? Would you recomend a slider mount for ease of enterance/exit? What brand would you use?
This has been a real hard one for me.
I want a good race seat..... I'm about your size and have tried Kirkey's 18" and the fit is the best. I'm just conserned that getting in and out will be a bitch with out a slider mount.
Thanks for the info and pics!
Received 8,958 Likes
If you are installing in a C6 with side airbags and heated seats the biggest problem with the Hardbar rails is the wiring harness going to the driver's seat. It is larger in diameter than the C5 harness and you will have to work around it as the rails don't fit if you don't do something about it.
Bill
So now my seating position is pretty upright with my knees bent only slightly. This puts the seat pretty far back, so a slider wouldn't necessarily help you enter and exit. The side bolster is the obstacle and some people have bent those to help make it easier. I'm going to leave mine as is and see if I can find a graceful way to get in and out.
Bill
Bill
First off thanks to naschmitz and Bill Dearborn for your reply!!!
I have been looking for good info for the BGS... (Big Guys Seat)
I even started a thread a little while back to find more info on what fits and what doesn't with no reply
This is the most good stuff on this subject geared to a C6 !!!!!
I wanted a fiberglass cushie seat.... easy in and out, but come to the reality that's not going to work driving a Vette
Now I can move forward on my track only Z06 C6
Best Regards,
G
Best Regards,
G
I pulled both the airbag connector and seat power connectors back towards the door sills where they leave the wiring harness. That way the Hardbar rails aren't sitting on any wires. I slit the carpeting as well so I could fold it back and bolt the Hardbar rails directly to the floorpan. The stud extenders are long enough so you dont HAVE to do this, but I just felt better bolting things together without any insulation, carpet, or wiring in between.
Bill
Best Regards,
G
Best Regards,
G
I did have to shim the hardbar brackets with two washers on the outboard sides because the seat studs are too far inboard. And the shoulder bolster just kisses the door panel when you close it -- I don't think I am going to do anything about that because I am pretty broad shouldered and need the room up high.
But the 18s do fill up the available space. I was glad I could still open the center console and that the shoulder bolsters didn't interfere with that.
Suckin' gas, haulin' ass.
I'm a big guy myself (5'10" 250 lbs with a 40" waist) and have been looking at seats for my C4. I think I have decided on the Sparco Evo 3 or Evo XL, I believe it's the same seat. The only question I have is will it fit in the car.
From a popular safety gear website:
Evo is good for waist sizes from 30-34"
Evo L is good for waist sizes from 34-38"
Evo XL is good for waist sizes from 38-42"
Will the Evo XL fit in a Corvette? (Particularly a C4)
I can't say about the C4 but it's to big for the C6!
Measure the floor pan to the inside of the door..... I bet you find it's to wide.
That was one of my choices I wanted to put in the car, but no can do
Good luck on your search.
#33
I believe the seat area in the C4 is smaller than the area in a C5 or C6. It may be difficult in a C4.
Here's a picture of the Corbeau FX1 Pro (fits up to a 36" waist) in my C5
