Let me ask another way, who's LS3 HASN"T blown up on the track
#161
St. Jude Donor '11-'12-'13-'14
Good info Chris, thank you again.
I've debated selling my C6 coupe for awhile but have really grown to love the car and don't really want to sell it.
That leaves me with needing a dry sump when/if I decide I want to road race.
I've looked into the idea of swapping out the crank/oiling system/oil pan/etc to add in a factory GS/Z06 dry sump. Do you have any thoughts on that?
I don't want to lose my a/c so some of the aftermarket dry sump kits are out. I've looked into the AVIAD kit that bolts on the passenger side head but I'm not certain on which kit would fit my goals the best.
#162
So here's the deal. If you just want to use your car for track days and schools, then use the stock GS/Z06 system. But if you plan to race, you'll have to scrap the a/c...because of the extra weight and drag placed on the engine.
I've got the ARE system on mine and I think Jason Berkeley is using the AVIAD. They both work well and are better than the stock GS/Z06 version. But you've got to make a decision on what you want to do with the car. Schools = keep the a/c and use the stock system.
Race = drop the a/c and go with any dry sump system. If you do plan to race though, and want to win, you'll want the best!
#163
Thanks again Chris.
I would just like to take some driving classes and spend some time around Sebring when they have open track days.
My vette is my daily driver and as such, won't be turned into a racecar anytime soon.
Regarding the drag on the engine, the a/c uses a separate belt so why couldn't I just disconnect that belt when I was doing any form of racing and eliminate the drag on the motor. Also, regarding the weight, I can't imagine the a/c weighing more than 50-75lbs total so what is it that I'm missing?
I'm not trying to dispute anything you're saying, I'm just trying to make sure I understand.
Also, what is it about the ARE and AVIAD systems that perform so much better than the GS/Z06/ZR1 systems? Can the OEM systems fail or do they just not provide enough oil pressure/cooling/etc?
Thanks again for the info, I love this stuff
#164
As I said, it just depends on how competitive you want to be. If we are equal drivers and the cars are equally prepared, etc...but you are 50-75 lbs heavier, then you will be .5 to .75 seconds per lap slower than me. Plus, your weight is up front and high (behind the dash pad too). After a 20 lap race, you won't even be in my rear view mirror. You'll have higher tire wear rate, more brake wear, etc, etc, etc. How competitive do you want to be?
The stock system is good, but the ARE (for instance) is a 3-stage scavenge system. In other words, there is a slight vacuum inside the engine so you won't have those internal pressure problems, reduced ring flutter, etc. = more consistent power! Then there's the reduced foaming benefit, slightly higher capacity, better cooling and so on.
If you're just using it for track days, then the stock system may be for you. But if you're trying to race and be competitive, there are better options.
#165
Great info, thanks again Chris.
That makes a lot more sense. I guess I never realized how important weight could me.
For now, I'm just wanting to make some hot laps around a track and push the car to the higher limits.
On a side note, do you have any pictures, details on your LS3 racecar? I'd love to see some detailed pictures of it in full race trim etc.
#166
#167
#168
I ran with my AC for a long time. I finally pulled it for the weight and cooling benefits (the condenser removal helped the airflow up front quite a bit).
I run one of the lightest corvettes in my division, and it pays off. Less brake wear, less tire wear, lower lap times.
#169
#170
I just wanted to let you know you don't have to pull the belt off when tracking your vette. I understand why dropping the weight is key for race only cars but for street / track cars, the compressor has a clutch on it. Therefore the only drag is the belt turning the clutch. If you do have the AC on when your on the track, there is also a calibration in the system that will turn off the AC under high throttle conditions.
Plus it's nice to have it on while you are waiting for your session to go off. Different for race only cars.
#171
This past tues at thunderbolt i was following a ls3 w/ toyo r88's and it let go right in front of me, got it on the go pro in car.. guy said it was his 15th track day on the setup... he even made a comment in the morning how he is on the verge with the oem oiling system on the R88's..
#172
I seem to hear this too from racers with the drysump. I also hear the
C6 Z06 is blowing up too. I guess we'll have to wait for the next gen
C7 and hope GM figures it out. So what has GM rumoured to have done? They Stopped production of LS6 crates the only motor that was bullit-proof. I know at least one recent T1 racer that had a bit of a time finding an LS6 crate. While not race class legal for many classes I think the LS6 with a cam is a better motor than an LS3 for reliability and comparable power.
#173
Dead stock they should be OK with 1 quart over?
Taking a buddy with a 08 LS3 to a HPDE. Dead stock, new driver, street tires. The most aggressive it will get driven will be with me taking him around the track.
#174
You should be OK with an all stock system. Watch the oil temps though if you start to push it. If you see 300+, back it off for a lap or two.
#175
Yep, Mike McGinley and I ran the first 2 prototype pans developed by the GM engineers we were working with back in mid 08. They kept the engine alive, but didn't solve all the problems. There were still extremely high oil temps, blow-by and the pressures were nowhere near as high as they should have been. Turning left is still the problem with the pan.
My best advice to you or anyone else with an LS3 remains the same - put a dry sump on there. It's the only way to ensure it'll live.
#176
Are the 2 types of "batwing" pans the same? Other than the C5 being 2 piece and the C6 being solid? Witch did you test? I cant find the oil pan for sale anywhere when I type the part # from GM racing.(12630477?)
#177
No, the C5 and C6 pans are different. I don't know if you can even find those things any more. The only ones I've ever seen were hand-made ones by the GM engineers. Once they (SCCA) approved the dry sump, I gave my old pan to Joe at Phoenix and they installed the sump. You may want to check with Phoenix and see if they have one.
I'm sure that the high oil temps affected the pressures a little, but the big problem was just the poor stock oiling system...for anything other than about 1.1Gs. All that oil pooling in the heads and the ring blow-by was just terrible for pressures and temps. The sump does solve it.
#178
Location: If you don't weigh in you don't wrestle Road America
Mike Tracy Sr. had one for sale a while back - so did Joe at Pheonix.
Here's the for sale thread for Mikes a while back.
http://forums.corvetteforum.com/c6-p...2-and-ls3.html
#179
Thanks for the link but I think it sold. It seems perfect for what Ill be doing. What is a good price for a used dry sump? Is a dry sump usually ok to buy used?
What is involved in the install of a dry sump? any drilling or machine work to the block?
#180
The ARE system is a bolt on system, but the hard part is/are the different configuration(s) of the lines and fittings. Just about everyone has their own coolers, etc., so that complicates things. You can easily spend $1500 on lines, fittings and coolers...and generally, there are no "one size fits all" set-ups. I think the Phoenix guys put together a package that comes pretty close though.
