tire pressure for autoX-ing Hankook V12's
Old 05-19-2011, 06:48 PM
GeneT
GeneT's Avatar
Default tire pressure for autoX-ing Hankook V12's
I'm getting a set of Hankook V12 evo's to replace my F1 run-flats.
I run 32lb with the run flats.
Does anyone autocross with the Hankooks and what pressures F/R do you run ??
Old 05-19-2011, 07:27 PM
avizandum
avizandum's Avatar
I have no first-hand experience, but it is my understanding these tires have a relatively soft sidewall. I'd start at no less than 35 lbs. cold (or more) and go from there.
Quick Reply: tire pressure for autoX-ing Hankook V12's
