AutoX Classification and info on any local rally/hillclimbs
Old 07-08-2011, 10:49 AM
el es tu
el es tu's Avatar
Default AutoX Classification and info on any local rally/hillclimbs
Right now Im testing/prepping my car to get the setup to my liking and was wondering about how the scca classifies C6's from the factory? STU?
I was also wondering where I would be put if I eventually ran 255 front and 295 rear sized Hoosier R6's? Would this be SP?
Aside from AutoX, I would like to get into some tarmac rally/hillclimb events (not the drive slow on street road rally thing scca does).
Is/will there be any of this going on in the va/nc/nj/md area?
Thank you!
Old 07-08-2011, 11:11 AM
Jason
Jason's Avatar
CI 4-5-6-7 Veteran
Pretty sure you'll need a cage for Hillclimbs. At least I'd sure as hell hope so.
Old 07-08-2011, 11:24 AM
bsalie99
bsalie99's Avatar
For a SCCA Autox classing we need to know more about the car
It could be super stock, ASP or SSM
Old 07-08-2011, 01:03 PM
torque*is*cheap
torque*is*cheap's Avatar
For Auto-x, all "standard" C6 Vettes are Super Stock (SS), as are C5 Z)6s.
Old 07-08-2011, 01:24 PM
TedDBere
TedDBere's Avatar
All C6s from the factory are in SS except the ZR1 which is in ASP
In SCCA tire size is free as long as they are mounted on the stock size rims (+ or - 0.25 inch offset) as they came from the factory.
Old 07-09-2011, 07:38 AM
el es tu
el es tu's Avatar
My local scca website (old dominion scca) only lists Stock, ST,STR,STS,STX,STU,SP,SM SMF and SSM.
Would that mean I automatically will be put into SSM (the highest class they have lined up)?
Thanks for the replies!
Old 07-09-2011, 10:13 AM
NealB
NealB's Avatar
the SCCA rule book can be downloaded for free here
http://www.scca.org/contentpage.aspx?content=61
then look at page 71 for Stock Category allowances
and you will see that page 161 lists cars in Super Stock
Stock Category has several sub-classes, Super Stock being the one for the C6 (as long as it is "stock" as defined in the rules)
Regions may choose to use some or all of the classes, and may add Regional-only classes
rule book classification system is mandatory for Divisional and National level events
To AutoX Classification and info on any local rally/hillclimbs
Quick Reply: AutoX Classification and info on any local rally/hillclimbs
