Autocrossing Roll-bar requirements
Can anyone tell me whether a 4-point or 6-point roll-bar would be legal in most autocrossing events or is a full race cage required???
Re: Autocrossing Roll-bar requirements (BlackRocket)
autocrossing requires no rollbar of any kind, much less a cage. you can show up with any car and kill cones. any car, literally...
Received 9,002 Likes
If you are attending a NCCC autocross you will not need a roll bar as long as you do not fall into the Group 3 class. Things that get you into Group 3 are race only tires (slicks), extensive suspension changes, use of non-Corvette Engine parts or parts not available for the year, lightening of the valve train, porting and polishing the heads, etc. No Cure's car falls into this group however most do not.
Bill
Bill
Check with the sanctioning body sponsoring the autocross for their particular rules. You don't normally need a rollbar for autocross. But if you have one installed, whether its a bolt-in or welded in may affect the class you run in. Some consider a welded in rollbar as a means to stiffen the body and force you to run a higher class.
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Re: Autocrossing Roll-bar requirements (BluFRC)
I got bump from Group II to Exhibition since I don't have a rollbar otherwise I go into Group III
What drivetrain mod did that you ask?
oversized radiator! :cuss :smash:
Re: Autocrossing Roll-bar requirements (BrianCunningham)
Harness bars require that you run a racing harness, otherwise under protestations you will lose. Chassis stiffening if not using belts. If you have belts, then it is legal in stock classes. :crazy:
Re: Autocrossing Roll-bar requirements (Goody)
On my C3, because of the angle plug heads and aluminum intake, the local NCCC inspector required my to install a blow proof bellhousing and a rollbar. I installed a 4pt welded to the top of the frame rails and haven't had a problem since. IMHO it depends on the inspector sometimes ;) .
Re: Autocrossing Roll-bar requirements (no cure)
