C5/C6 Big Brake Kits - XYZ Holiday SPECIAL
Old 12-07-2011, 11:57 AM
0Superman09
Former Vendor
Superman09's Avatar
Default C5/C6 Big Brake Kits - XYZ Holiday SPECIAL
View and Order Online at:
http://shop.huronspeedproducts.com/C...Kit-XYZBBK.htm
Kits starting out STANDARD with:
355mm front and rear 2 piece fixed rotors, 6 piston front calipers, 4 piston rears. Standard caliper color choice, with sport pads and *FREE SHIPPING* for: $2995
To add options, larger rotors, etc. simply view the product on my website and add your options via the drop down menu's
355mm F/R fixed kits- $2995 shipped
355mm F/R floating kits- $3410 shipped
380mm F/R floating kits (8piston front/6 rear)- $4270 shipped
400mm F/ 380mm rear floating kits (8piston front/6 rear)- $4390 shipped
Substitute Race Pad- +$315
Add Race Pads w/ Sport Pads- +$450
Custom Caliper Color- +$300
This pricing is good through the first of the year only so don't miss out!
If you are in the market for a big brake kit for your C5/C6, you will not find a better bang for the buck than here!
Systems start at 355mm (14") and go up to 400mm (15.75")
Kits feature 2-piece rotors with lightweight aluminum hats in fixed or floating options.
Allow custom caliper finishes, pad options, 6-8 piston front calipers, 4-6 piston rear calipers, and much more!
All kits come complete with everything needed to COMPLETE your ENTIRE car, Front to Back!
Mounting hardware, new stainless teflon coated lines, instructions, and all components included!
*FREE SHIPPING*
Each kit includes;
-Two diamond cut slotted 2 piece rotors with aluminum center hats.
-Two squeeze forged aluminum calipers.
-Two hardened mounting brackets with high tensile strength steel fasteners and shims.
-Two teflon coated stainless steel brake lines.
-Two sets of street performance pads.
*The rear rotors retain the OEM parking brake function.
Available in red, yellow, or black Caliper finish.
***The calipers use standard AP, Ferodo, Pagid, Mintex etc pads and all spare parts are available. Pad change is quick and easy also! Here are the specs on their pads***
-Sport pads, ceramic, semi-metallic (supplied with the kits);
-Coefficient of friction - .46 - .53
-Temp range - 194 - 1,022
-Race pads, carbon, metal, graphite;
-Coefficient of friction - .5
-Temp range - 482 - 1,472
View here: http://shop.huronspeedproducts.com/C...Kit-XYZBBK.htm
Old 12-09-2011, 09:57 PM
0Superman09
Former Vendor
Superman09's Avatar
Old 12-11-2011, 07:59 AM
0Superman09
Former Vendor
Superman09's Avatar
Order now to start a good winter project to help you STOP next season!
Old 12-11-2011, 08:20 AM
WICKEDFRC
WICKEDFRC's Avatar
Received 1,652 Likes on 738 Posts
Looks like a great set up....two questions that may be good to answer are:
Weight compared to C6 Corvette BBK
And, it may not apply for all, but if interested, I would never purchase any Corvette parts exposing ABC, 123, XYZ as a name, regardless how good it may be. IMHO, it looks tacky and steals from your masterpiece.....
Can this set up be purchased without the XYZ branding?
Old 12-11-2011, 08:49 AM
0Superman09
Former Vendor
Superman09's Avatar
Are you referring to standard C6 brakes, C6 Z06 brakes, or C6 ZR1 brakes? Let me know and I can compare.
To answer your second question, my guess is no, but I will certainly ask to see if that is an option. My reason for guessing "no" is that it their way of marketing their product. It is for the same reason you will not buy blank Brembo's, Wilwoods, etc. as they all want to market their product. However, you always of course do have the option of simply sanding down the logo and refinishing the caliper to the finish of your choice! In the mean time, I will ask them and let you know as soon as I hear!
Edit: Unfortunately they cannot be had without the logo, but you still could certainly sand it down as it comes as a raised logo
To C5/C6 Big Brake Kits - XYZ Holiday SPECIAL
Quick Reply: C5/C6 Big Brake Kits - XYZ Holiday SPECIAL
