Anyone mount a front tow hook with Vararaam installed?
I used to think WD-40, Duct tape and Vicegrips were all that were needed for a toolbox... I now realize that Velcro is a cool addition.
You can get a piece of velcro and sew it into the strap... then attach another piece via double sided tape to the plate area. Voila... no more flapping and lose when you need it.
I could build something like that too, but I'd bet the factory part will cost less. Also, those screw in eyebolts have a pretty small opening that will make it difficult or impossible for a huge rope, that track safety oftentimes uses, to pass through. In order to get a large opening a huge (heavy and bulky) shank is used and corresponding mount. They are also more so designed for tie down of equipment. Some of the reasons I prefer a soft strap. In any case, anything can be made. Just depends how much you want to spend.
As of right now, I am looking to put hooks on the C5. I have a Vararam as well so it looks like my only option is through the middle too...
[IMG][/IMG]
After giving it a test run winching it up on my trailer, I had to cut the hole larger above the strap as the angle was trying to break the cover. It is much easier to hide there now as you can get your hand in there easier. I just hope the extra airflow doesn't hurt my aero.
St. Jude Donor '10
Where did you get the strap type?
I have a pheonix performance front hook that is hinged. The hook is removable, but I like this better for behind the plate.
[IMG][/IMG]
#37
Well it looks like I might not get my straps from Hardbar, since they have been MIA for a while.
Does anything have another suggestion for a soft hook to put in the front? This RaceQuip unit is looking like a winner:
http://www.summitracing.com/parts/vms-898148/overview/
#38
I would recommend taking the strap with the ring.
#39
What's min length for tow strap through the plate... I'd like as short as possible and still functional.
This one is 9"
http://www.amazon.com/gp/aw/d/B00BG423YA/ref=aw_wl_ov_dp_1_2?colid=3BHOG4RYW3DC7& coliid=I1Z3T7I8D2UU8R
This one is 9"
