This is what happens when you get bored on a Sunday............
Tedious is probably the best word but once you get in the mode it goes pretty fast. I did that before I did anything else and it only took about 8 hours to tear everything out, organize the individual harnesses and then shorten all the wires.
#35
Excellent progress for a days worth of hard work.
I'll echo the viking, I can't believe you are calling this a winter project when I am headed to the track next weekend. LOL.
-Kevin
-Kevin
#36
#37
I could join you at the track.....but I guess I would only be a spectator I guess there is some advantage to living up here....longer project season.
#39
It can save your behind too. I was "bored" two weekends ago so I pulled my valve covers to chetck my valvetrain. I noticed a rocker with a lot of play, like valve lash. Turned out to be a lifter with a bad roller bearing that had apparently gotten damaged before because of a broken valve spring. Luckily I caught it before it knicked the cam lobe. My boredum cost me a head gasket, a set of lifters for that side and the whole day....but Im sure it saved my motor.
