Hoosier rubber compounds
Old 03-04-2012, 02:26 PM
Everett Ogilvie
Everett Ogilvie's Avatar
Default Hoosier rubber compounds
How do you guys rate/compare the A6 with the slick compounds R80 and R100? How about life? Thanks for any input.
Old 03-04-2012, 05:15 PM
Gman57
Gman57's Avatar
Hope to hear some discussion on this
Old 03-05-2012, 01:21 PM
waddisme
Support Corvetteforum!
waddisme's Avatar
I bought like 12 scrub R80s for $500 back in the fall for HPDEs. I have 23 sessions on the first set so far. 1/2 of the sessions at VIR, 1/4 at Rd Atl and 1/4 at Charlotte/Daytona. Not corded yet and honestly not even looking like they need to be flipped. I don't push my car 10/10s, but the R888 scrubs I had barely got 8 sessions and I paid $200 plus for 4 of them.
Here is a typical 1 lap vid at VIR that shows about how hard I push them:
HTH
Old 03-05-2012, 04:59 PM
RX-Ben
RX-Ben's Avatar
What kind of air pressures do you run on R100s?
Old 03-05-2012, 05:26 PM
AU N EGL
AU N EGL's Avatar
My understanding is
A6s are the softest. then R6s
the R80s are softer then the R100s
The construction of the R80s and R100s are very different from the A6s and R6s
so not always apples to apples.
the Old VRLs were the same as the R6 rubber compound but a stiffer sidewall
Old 03-05-2012, 05:42 PM
RX-Ben
RX-Ben's Avatar
Yes, the R100s that I have (Conti Grand Am 285/645) have sharp shoulders, way different than the rounded A6/R6.
Old 03-05-2012, 05:45 PM
Everett Ogilvie
HTH
Thanks for posting this, looks like they work pretty well for you!
Everett Ogilvie
I wonder if the slicks are lighter weight than the A6 and R6 (for a similar size).
Old 03-05-2012, 08:45 PM
RacePro Engineering
RacePro Engineering's Avatar
Originally Posted by AU N EGL
My understanding is
Hi Tom,
I do not wish to put you on the proverbial spot, but where did this bit of MIS-information come from?
Ed
Old 03-05-2012, 08:58 PM
Corvee
Corvee's Avatar
On R100s I ran 25*cold and hot temps were 35-37* this past weekend in 50 - 60*ambient temps.
Old 03-05-2012, 09:22 PM
Sidney004
Sidney004's Avatar
The Conti GrandAm 285/645 is not the same as the R100. Different internal construction(the GrandAm was designed to sustain the loading on the banking at Daytona) I am not certain as to how the compound compares to the R100.
Old 03-05-2012, 10:13 PM
Racingswh
Racingswh's Avatar
Received 1,074 Likes on 644 Posts
From my research yes they are lighter than a comparable size A6. 325/710/19 at 27.6 lbs which is physically larger than the 325/30/19 A6 at 29 lbs.
Old 03-05-2012, 10:34 PM
1ED1
1ED1's Avatar
Race Pro
Instead of asking a question why don't you tell us what you know.
Old 03-05-2012, 10:49 PM
Gman57
Gman57's Avatar
Originally Posted by 1ED1
Race Pro
Old 03-05-2012, 11:06 PM
yooper
yooper's Avatar
Regarding the Conti's, what is the difference between the GT-O and the GT-R?
Old 03-05-2012, 11:18 PM
redtopz
redtopz's Avatar
Originally Posted by RacePro Engineering
Hi Tom,
Ed
I thought he just said the A6's are softer than R6's and the R80's are softer than R100's. Is that not true?
I ran a set of R80 F/R100 R before (off a porsche race car) and was impressed with the level of grip, the lack of fading off like an A6, and how long the tires lasted from a physical wear standpoint.
Old 03-05-2012, 11:23 PM
RacePro Engineering
Race Pro . . . . . Instead of asking a question why don't you tell us what you know.
Ed,
My name is Ed, just like yours!
I used to immediately post what I knew to be true. I found that, facts aside, folks would argue with me.
Not long ago, I took the time to revise and post here a pretty lengthy technical discussion on racing wheels and tires. It contains knowledge that we have gained over the years, not from theory, not from books, and certainly NOT from the world-wide-web; but from running real cars on real tracks, representing hours upon hours of testing.
Tom is usually "right-on" with his information, so somehow he has gotten something skewed, probably by someone else "speaking" authoritatively on a subject about which they know very little. I am just curious of the source.
Also, I am certain that Everett knows very well the mechanical grip ranking of all the Hoosiers in question, so there is no need for me to correct for his benefit. I believe he is more looking for first-hand experience on tire "behavior", consistancy, and wear characteristics.
For those interested, there was another thread some time ago on which I discussed the use of a durometer. That would be good to search for too.
Ed
To Hoosier rubber compounds
Old 03-05-2012, 11:28 PM
RacePro Engineering
What you wrote is true. However, "Softest" is a superlative, not a comparative. If my understanding of grammer is getting in the way, then, Ted, I apologise.
Slicks are in a category of their own! And, if one is impressed with the current radials, especially the 80 and 100 compounds, one should try a nice set of bias-ply - maybe a 45 compound - whole other OTHER world.
Ed
Old 03-05-2012, 11:36 PM
travisnd
travisnd's Avatar
Too bad NASA has the .75 penalty for slicks. I'd like to try some
Old 03-05-2012, 11:52 PM
RacePro Engineering
Originally Posted by travisnd
Too bad NASA has the .75 penalty for slicks. I'd like to try some :yesnod:
I know you would, and you would be one who fully used the additional grip!
?? Should be .075 ??
And, in case there is any (ANY) doubt whatsoever about the inherent grip differences between a good DOT radial, and a good slick, one has only to look at this NASA "Equalization Factor" in added weight.
Thanks for reminding me, Travis.
Ed
Quick Reply: Hoosier rubber compounds
