Latina Seca sound question??
Old 05-31-2012, 09:23 AM
Charley Hoyt
Charley Hoyt's Avatar
Default Laguna Seca sound question??
Will a stock LS3 C6 with dual mode exhaust meet the 90 db sound limit at Laguna Seca?
Thanks,
Charley
Old 05-31-2012, 11:10 AM
63Corvette
63Corvette's Avatar
Charlie I think only wheelchairs, soapbox racers, and prams meet the 90db limit. 90db is really quiet
Old 05-31-2012, 11:30 AM
AU N EGL
AU N EGL's Avatar
if 90dbs is the limit, do the locals stop ppl from blowing horns ?
Old 05-31-2012, 12:16 PM
TNTC4VETTE
Will work for HPDE time.
Support Corvetteforum!
TNTC4VETTE's Avatar
Wow, I thought AMP's 96db ruling was bad.
Old 05-31-2012, 01:31 PM
moose.b3
moose.b3's Avatar
When I went to Laugna Seca 3 months ago, I wired the baffles closed. I have the modded mufflers and knew it was too loud with 98db. I know they have different limits with different events,but with H.O.D. the limit was 92 db. It did seem that a few cars were louder than 92 db and nobody was black flagged.
Old 05-31-2012, 01:59 PM
btlgrd
btlgrd's Avatar
AMP's noise limit is 98db.
Old 05-31-2012, 03:24 PM
jcosta79
jcosta79's Avatar
Not to stray off topic, but were you trying to search for a different webpage when you typed the title for this thread?
Old 05-31-2012, 03:29 PM
Crepitus
Crepitus's Avatar
How its measured has a lot to do with it. If its 6' from the end of the pipe they wont be able to mow the grass. If its behind pit wall....
Old 05-31-2012, 03:41 PM
Crepitus
Crepitus's Avatar
How its measured has a lot to do with it. If its 6' from the end of the pipe they wont be able to mow the grass. If its behind pit wall.... The local short track here was built in 1948 Now we have a housing development near buy and a budget for noise litigation. There lawn mowers and air conditioners cause about 5X the noise in their neighborhood. Exhaust pipe termination has a big effect on perceived noise. If you can swap a cat back on for track day use that dumps with turn downs near the rear diff it should help a lot. For stop n go traffic, maby not.
ed Sorry bout the dup post
Old 05-31-2012, 05:59 PM
Charley Hoyt
Oops, my I pad self corrects some words....I guess it didn't like Lauguna and corrected it, and I didn't notice.
Old 05-31-2012, 06:31 PM
Screamin Z
Screamin Z's Avatar
Only a tesla would pass the sound limit.
Old 05-31-2012, 07:03 PM
dbratten
dbratten's Avatar
You should be fine although you may need to keep the baffles closed. On some days, due to weather, sounds will register higher. But typically, a stock C6 Z06 will pass.
Sound is measured in the hut to the right side of the track between turns 5 & 6 -- an uphill climb. You can see it on most videos. Short shifting or letting off the gas will allow most street cars to pass. Others have created an LS exhaust that directs the sound down and to the left to be able to remain at full throttle.
Have fun out there.
Old 06-01-2012, 02:10 PM
Bedouin
Bedouin's Avatar
Charley, you'll be just fine. I drove L-S twice in the last couple months; '12 GS w/ stock LS3, 6spd & NPP with the exh flaps wide open the entire time & had no noise violations whatsoever.
There was an LS2 with Z06 headers & really loud BB Fusions & he just backed off the gas after T5 & I don't think they gave him any violations either. Have fun!
Old 06-01-2012, 02:32 PM
TNTC4VETTE
TNTC4VETTE's Avatar
Sorry about the 2db shortchange. My car fails anything below 100 anyhow. Most of us have to lift at Roebling, and it's 103.
Old 06-02-2012, 12:02 AM
Charley Hoyt
Thanks for all of the help.
To Latina Seca sound question??
Quick Reply: Latina Seca sound question??
