I've never seen this - Help me diagnose brake issue
Track Junky
Hey fellas, need a keen eye to help me. These are track only brake pads on a 2005 Z51 base model. Carbotech XP-20 with 3 track days on them. The configuration is exactly as shown in the first pic - the bend pads are inside only.
Overheating? I run with the nannies on with Hoosier R6's, but only see AH kick on a couple times per session. I have DRM SS pistons, SS brake lines, Motul RBF 600 fluid, Quantum fog light cooling on stock Z51 calipers.
Thoughts? I've never seen or even heard about the leading edge bending back like this.
I plan on sending these pics to Carbotech Adam tonight but I think the long term solution may be a BBK.
I would guess that the inner pads were hanging up and not free to move in and out in the caliper body. Once you got heat in the backing plate it would not be hard to permanently deform them.
Did you have a really spongy pedal to start out with?
Track Junky
Looks to me like the pads are binding on the caliper. Caliper is obviously working. Something happened on your last installation. The tabs are obviously not sliding within the clips on one end. I'll have to take another look at my calipers to see what the heck is going on there.
Track Junky
Lubricated the tabs before the most recent track day. The pedal felt slightly long (I hear that's normal with stock calipers) and just a bit spongy but never felt like the fluid was ready to boil. The pads were about 60-70% before the latest track day and these last 4 sessions were pretty intense. Pedal, although not completely firm, was consistent all day - never got noticeably worse as the day progressed.
I literally just did that to a set of pads on a Miata. What I found (tonight) was the inner pad was hanging up on the anti-rattle clip inside the caliper. I replaced the clip with a good one and rebent the pad (street pad).
Obviously different car and different calipers, but as the folks above stated, you may have had something similar going on.
-Kevin
-Kevin
Track Junky
These pads have been in he calipers twice before with no issue. They moved freely during install and were lubricated. They also fell right out, no binding whatsoever - that's why I'm so baffled.
I'm gonna take the clips off today after work to look for signs of binding or other damage. I'd really like to find the smoking gun here so I can explain it to myself.
Thanks for the input so far.
I swap back and forth track pads to street pads on my M3. I ruined a set of used track pads one time compressing them with a C clamp: I compress while still fully assembled, its just quicker, not necessarily better obviously... They hung up and the inside and bent both ears on the inside pad. Maybe a similar situation here? Just throwing it out there.
Supporting Vendor
St. Jude Donor '11,'13
They definitely got hung up in the caliper, no doubt about that. We have seen this before, it can happen for any number of reasons. The pistons not properly or fully retracting, debris getting in the way, knock-back leading to the pads getting cocked in the caliper, etc..... You need to take a good look at his calipers and be sure they aren't having a problem and that there are no issues in the contact area's where the pad touches the caliper. It produces a TREMENDOUS amount of heat, which softens the backing plates and leads to the pistons bending the backing plate and cracking the friction material.
On a side note your new pads shipped yesterday.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
I had this happen to my right rear XP10 at RD ATL back in Apr. Soft pedal with reduce braking making me think it was a fluid thing. Flushed brakes with no improvement. Did the rest of my weekend with soft pedal. When I went to repl with street pads, it looked just like yours. I assumed I had installed wrong. Hasn't happened since.
Adam - if it is a manufacturing defect, I can pm you my address so you can send me the repl set as I had to throw mine away.
Track Junky
Track Junky
And I had to pay for new pads, no freebies here. It would be nice though.
Adam, care to be my sponser? I won't go broke and will give your pads a run for their money, lol!!!
Track Junky
On to bigger and better brakes after this next track day I think. Started shopping around this morning, just didn't have time to buy and install before this weekend. Hopefully the calipers and new pads can hang on for one more event!
Supporting Vendor
I will be extra cautious on this next set during install, being sure to lubricate everything well and check for free, unrestricted movement.
Supporting Vendor
Track Junky
