250 ft lb torque wrench suggestions
Old 03-20-2013, 06:48 PM
froggy47
froggy47's Avatar
Default 250 ft lb torque wrench suggestions
I will be working with the car on jack stands so not a lot of swing room or room to put a jack handle extension on.
I am strong enough to put 150/60/70 or so (without an extension)but I need to go 240 (Balancer).
Is there a wrench that has some "multiplier" on it to get to the higher torque values without having to muscle it?
I don't want to guess with my impact gun.
Old 03-20-2013, 08:22 PM
68sixspeed
68sixspeed's Avatar
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
there are gear reduction heads but I've done 250 ft-lb before - my larger torque wrench maxes at 260 and is about 2ft long, so that is only 125lb pull. If you can get the wrench in position to use your weight it shouldn't be an issue.
Old 03-20-2013, 09:26 PM
froggy47
froggy47's Avatar
Thanks!
Old 03-21-2013, 07:51 AM
VetteDrmr
VetteDrmr's Avatar
Received 1,397 Likes on 749 Posts
My 1/2" torque wrench from Home Depot goes to 250 and is a bit longer than the Craftsman wrenches. Lifetime warrenty, too!
HTH, and have a good one,
Mike
Old 03-21-2013, 11:51 AM
froggy47
froggy47's Avatar
Mike
I have a wimpy 1/2 inch only goes to 150, time for a new one.
Old 03-21-2013, 02:06 PM
Scooter70
Scooter70's Avatar
You won't get 250ft-lbs on that bolt. Just tighten it as much as you can with an extension on a breaker bar and it won't move. Every How-To on the subject says the same thing.
Old 03-21-2013, 03:09 PM
GOTHAM VETTE
GOTHAM VETTE's Avatar
Make sure you have a flywheel holding tool as well!
Old 03-21-2013, 03:19 PM
froggy47
froggy47's Avatar
Is there a diy way to hold it from turning w/out special tool?
Old 03-21-2013, 03:58 PM
trackboss
trackboss's Avatar
Put it in gear and parking brake on. I think I used 4th when I did mine and it held well. The clutch does often slip a bit, but it should be enough to torque down that bolt. FWIW, I use a matco torque wrench for high torque bolts.
Old 03-21-2013, 06:36 PM
froggy47
froggy47's Avatar
I KNEW there had to be a way, thanks, the rear wheels will be off the ground, but my p brake is a strong one and the clutch s/b ok.
Old 03-21-2013, 07:32 PM
GOTHAM VETTE
P brake must be stronger than mine, because that wasn't enough for me.
Hopefully it'll do the trick for you.
Old 03-21-2013, 09:29 PM
froggy47
froggy47's Avatar
Originally Posted by gotham vette
p brake must be stronger than mine, because that wasn't enough for me.
Old 03-22-2013, 01:52 AM
trackboss
trackboss's Avatar
Get a couple friends to hold the rear tires. At that point it's just a matter of picking the right gear to have just enough leverage against the motor, but not overcome the clutch grip.
Old 03-22-2013, 08:21 AM
geerookie
geerookie's Avatar
Or 2x4's in the rear wheels.
Old 03-22-2013, 10:12 AM
vette6aut0x
vette6aut0x's Avatar
2x4 rear wheels, 6th gear, parking brake.
Old 03-22-2013, 01:00 PM
froggy47
froggy47's Avatar
So just shove the wood thru the wheel so it binds on the caliper somewhere?
Old 03-22-2013, 02:52 PM
brkntrxn
brkntrxn's Avatar
Yep.
And Kobalt torque wrenches at Lowe's have been redesigned and also carry the lifetime warranty.
To 250 ft lb torque wrench suggestions
Old 03-22-2013, 11:16 PM
AYello1
AYello1's Avatar
Snap-on...expensive, but well worth it. I recently bought a 3/8" drive, and while I was on the (snap-on) truck, I had my fathers 1/2" drive checked for accuracy. It's been used routinely, by both he & I, since he bought it in 1962, without any servicing. It was still, dead-on accurate.
Also, be very cautious about how you use a torque wrench. Torque values are affected by handle length (no cheater bars!), clean/dirty & lubed/dry threads. If using crowsfoot attachments, the angle used, makes a difference. If you're going to use it improperly, there's no point in using one at all. Google "torque wrench, torque values, etc" for good information.
Old 03-23-2013, 02:04 PM
froggy47
froggy47's Avatar
Thanks for the post. I understand all that about doing proper torque except for the cheater bar. I thought a cheater bar just compensated for lack of "muscle" from the mechanics end of the process?
Old 03-23-2013, 11:04 PM
trackboss
trackboss's Avatar
I have several torque wrenches, but my go-to one is the ATD 101. I recenlty had it re-calibrated and the main reason I sent it back was because the numbers are painted on so they tend to rub off. If I remember correclty I have sent it back twice for that reason. The customer service is first class and they have always taken care of me.
http://atdtools.com/101
My matco is a sweet tool, but I only use it for big stuff.
Quick Reply: 250 ft lb torque wrench suggestions
