hoosier slicks - new - 6 years old
Old 03-22-2013, 11:14 AM
CanadianVetster
CanadianVetster's Avatar
Default hoosier slicks - new - 6 years old
I have two new rear sticker Hoosier slicks.
Could I but two new fronts and make a set.
Would you run these new 6 year old rears on your car?
Is it a bad idea to match new 6 years old rear tires with two new new fronts.
Tires were property stored in heated/cooled garage since new and look perfect.
I don't want to cheap out on a couple of tires and run into any issues..
Thanks........
Old 03-22-2013, 11:41 AM
EyeMaster
EyeMaster's Avatar
It depends on speeds you plan on running. From past experience, I always want more grip in the rear, or equal grip everywhere. If your going to unbalance by having more grip in the front, be prepared to lose the rear end here and there, so I would stick to autocross, where the damage is almost non existent.
Of course, the remaining part of the equation is: Will the old really grip less? That, I can only assume.
Old 03-22-2013, 02:56 PM
Sidney004
Sidney004's Avatar
They're just too old to run.
Old 03-22-2013, 03:51 PM
froggy47
froggy47's Avatar
I would use them, being aware of the significant lowering of rear grip due to age, compensate as best you can with setup there are many ways.
I would not track them.
Old 03-23-2013, 11:10 PM
turnleft
turnleft's Avatar
Get new tires! All the base stock that keeps race tires viable are dried out. Those tires will go away on you quickly and without any warning.
To hoosier slicks - new - 6 years old
Quick Reply: hoosier slicks - new - 6 years old
